Thread: Need advice to remodel steel wall to concrete block pool
    I have a 20x32 in ground steel wall which I would like to make it to a 20x40. I was thinking of doing it on cement block due to money savings. Also two of the walls are getting pushed in and it need completely new plumbing and electrical which is where I need some help. I seen a few cement block pools but nothing really helpful. I work construction on the side and a mechanic for a full time job. Any help would be nice
    22,550
    Re: Need advice to remodel steel wall to concrete block pool
    Welcome to TFP.
    take a look at Dave's (Duraleigh) pool build thread. That should give you some reading material. You're basically going to e building a new pool.
    38,290
    Welcome to TFP!!!
    Here is the thread Dave J. was referring to for Dave S. pool build:
    an-unusual-pool-build-t10597.html
    MBG75's Avatar
    Jun 2013
    Long Island
    184
    Tried to reply to your message. Seems u have pm disabled.
    25k IG vinyl SWG Haywood 4830de 1.5hp TF-100
    Thanks. The is one nice big pool. Any recommendations on equipment? Was thinking an SWG, but not sure. I would like to start getting all the materials I will need during the winter.
    38,290
    Filter size recommendations are based on pool volume. For the pump, a 1 hp 2 speed is likely plenty big, unless there are some high flow needs we are not aware of.
    Size the SWG cell for 1.5 to 3 times the volume of your pool.
