Thread: Any way to replace the flow switch cable?
    Apr 2012
    South east VA
    26
    Hello, I was wondering if there was any way to just replace the flow switch cable without buying a whole new flow switch as the cable just got cut? My cell is a hayward goldline...
    18' above ground pool - 7500 gallons
    Hayward Aqua-trol SWG
    TF-100 test kit with speedstir
    22,537
    Re: Any way to replace the flow switch cable?
    There have been a couple people that have spliced the cable, but I don't remember how it held up. Seems like if you did a good job splicing and insulating the cable it should work. There are also some pretty inexpensive place to get a new switch.
    Apr 2012
    South east VA
    26
    Thanks for the quick reply, Do you have a place that you would recommend to get one? Or just do a google search?
    38,235
    The switch screws right out of the T-fitting, so it is easy enough to replace with no plumbing required. Just Google to find one
    But in the short term you could just splice it ... It just works on continuity, so even a really bad job like just wire nutting them together will work for awhile.
