Thread: Pool size
    Aug 2013
    Brighton, MI
    62
    Pool size
    Original owners stated that the pool is 36000 gal. Is that on par for a 20 x 40 9ft deep end pool?
    20 x 40 28k gallon Salt Water Vinyl IGP, Hayward pump and Sand filter
    22,553
    Re: Pool size
    That sounds about right. It's probably a little smaller than that but not enough to be too concerned about.
    38,546
    Re: Pool size
    Depends on the shape and the depth profile ...
    Is it oval / freeform or rectangular? How much is deep?
    I would guess it is less as well, but not sure how much so.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pool size
    Like the others have said it depends on exact profile, a traditional 20x40 with equal deep / shallow split is going to be in the 36,000 gallon ballpark, on the low side it may be as small as about 32,000 gallons, either way for now dose as if it were 36,000 gallons, if you get bigger changes than expect reduce your estimate of size next time and go from there.
    Ike
    Aug 2013
    Brighton, MI
    62
    Re: Pool size
    Its rectangular with a curve under the diving board adding a little length. Thanks for the confirmation , it sounds like it's about right.
