Results 1 to 8 of 8
Thread: Pump Replacement Pipe Size.
    Apr 2013
    Fayetteville, GA
    84
    My old pump has 2" pipe and 1.25 HP-
    New pump has 1 1/2" pipe 1.5 HP-
    Does any of this matter?
    THX
    18 x 36' Liner ~26,000g, 1 Skimmer (Supply)- 2 & 1 1/2" pipe, 3 Returns (jets), HEAD- ?, FILTER- Hayward 12002, 230v, SWG- AUTOPILOT DIG-220, PUMP- Challenger 346204 w/ USA MOTOR (rebuilt) SF 1.25/,02, CLEANER- Polaris 280- AO Smith 3/4hp., FEATURE- Hayward 1.5 HP Super Pump.
    38,537
    Re: Pump Replacement Pipe Size.
    You mean the threads are smaller? Or the pipe fitting is smaller? Or both?
    Just use the proper adapter fittings get back up to the 2" pipe as needed.
    Apr 2013
    Fayetteville, GA
    84
    both.
    Will not the 1.5" have work harder. does this matter?
    38,537
    Does not matter. The pump would work through smaller pipe, just at a lower flow rate. Are you not able to find a 1.5" thread with a 2" pipe couple? Then you would not need adapters.
    With what you have, you likely need a short 1.5" pipe into that fitting, then a 1.5"/2" reducer on the other end of the pipe, then a 2" coupler to the reducer and the other end to the pipe.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The restriction at your new 1.5 HP Hayward Superpump will will effect things some, but much of the reason for going with 2 inch pipe over 1.5 is the flow accumulated flow restriction down the length of the pipe.
    Ike
    Apr 2013
    Fayetteville, GA
    84
    maybe because im new but I have posted 2 responses and they have not posted yet.
    Apr 2013
    Fayetteville, GA
    84
    Try again...
    More to my story-
    I'm adding a water feature and needed to buy an additional pump. There will be 3 water spouts on the feature but with a 5' rise and a run of ~ 40'. (I assume pretty low demand.)
    My thinking is since my existing pool pump in a little old (1.25HP) and maybe undersized I will use it for the feature and buy a new 1.5HP pump for the pool. I bought the Hayward Superpump but was surprised to see the 1.5" pipe sizes.
    My pool 18 x 36 ~ 26K gallon in GA....is a 1.25HP big enough?
    Apr 2013
    Fayetteville, GA
    84
    Yes thanks...all very doable just wondering about the hydraulic dynamics......
