Page 1 of 4 1234 LastLast
Results 1 to 20 of 78
Thread: Problem with DE Blowing through Sand Filter
    May 2013
    North East Ohio
    959
    Well this is a new one for the group...
    (I revised this subject to reflect what I now think is a real problem with DE blowing through the Sand (last post has those details)
    My water is perfectly clear, except at night in the LED I see floaties...
    So the decision to ADD DE to make it perfect happened.
    PROBLEM IS - I have this DANG Pre-Filter that my PB insisted works...and guess what it does...it seems that ALL the DE (3 cups) ended up in the Pre-Filter and none in the sand as the pressure never moved.
    Now I did this on high speed, as that is what I was told.
    Anybody have any new techniques that might work ? Good news is this dang Pre-Filter ROCKS - but I guess it is not catching the floaties, just the FINE Particles which I guess is what DE is.
    [attachment=0:3r3k6lka]mc16.jpg[/attachment:3r3k6lka]
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: New Challenge Adding DE to Sand Filter
    Can you open up the top of the sand filter and add it directly to the sand chamber?
    Never tried it but it sounds like it would work.
    FYI. Not a sand filter expert.
    -- Guy --
    May 2013
    North East Ohio
    959
    Quote Originally Posted by techguy
    Boy not easily for sure...at least I don't see how it would be easy.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Do you not have any unions or any other fitting that allow you to get into your filter?
    Photos of your equipment pad might help us help you.
    -- Guy --
    Aug 2010
    Dallas, TX
    4,052
    3 cups sounds like a lot. 1 cup is enough to raise mine 1psi, and when I do that it will very rapidly take the filter to capacity as it clears the water.
    I've seen floaties in properly filtered pools with DE filters. It is most likely impossible to get it all out. In fact, I'll go out on a limb and say there's no way you'll get the water perfectly clear within the light's beam at night.
    May 2013
    North East Ohio
    959
    Mmmmm, I will take a few pics later this afternoon.
    May 2013
    North East Ohio
    959
    Quote Originally Posted by RobbieH
    Yeah I don't expect perfect, but I just saw a few too many floaties and was hoping DE would help. There has got to be a easy way....like mentioned above I will post pics later if that helps.
    Aug 2010
    Dallas, TX
    4,052
    Those LEDs make a very sharp, focused beam. I've seen many post about the floaties, and even with DE filters they are not getting rid of all of them.
    May 2013
    North East Ohio
    959
    Attached are a few pics....
    Now I am concerned I really got DE back into the pool vs. ALL in the MC ? As my pressure never climbed.
    This first picture is a TON of debris from a HUGE storm, the white is the DE I am thinking of course...
    [attachment=2:2pziyw23]DE blow back.jpg[/attachment:2pziyw23]
    [attachment=1:2pziyw23]Pump.jpg[/attachment:2pziyw23]
    [attachment=0:2pziyw23]Pump 1.jpg[/attachment:2pziyw23]
    May 2013
    North East Ohio
    959
    And the last pic....
    [attachment=0:3lher77z]Pump 2.jpg[/attachment:3lher77z]
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    DE helps, but you won't likely see what you want just from DE to a SF. Not for the effort it will take with your set up I don't think.
    Essential Links:
    May 2013
    North East Ohio
    959
    Anybody want to buy 25 lbs of DE cheap
    On a serious note...any way to get DE in this setup ?
    What if I add DE on LOW SPEED, in theory that would make the Multi-Cyclone less effective perhaps. Still not sure why I am getting a bit of DE blow by though ? Any ideas ?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Umm, I was thinking. Are those unions on the last leg out of the cyclone? If so, you could disconnect there or cut in one. You could then use a flex funnel like you would for oil changes. Stick the tip in the MP valve, and pour some DE slurry into it that way. You'd have to drain a little water out of the SF first, but I bet it would work. I sure don't think it would be worth taking the MP off the filter body though.
    Essential Links:
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Wait, those are unions. Just take out the cyclone, and cut in a straight run in it's place. Replace cyclone as you wish. Still a lot of hassle for the reward...but that would work.
    Essential Links:
    May 2013
    North East Ohio
    959
    Quick Update (I will work on how to get DE in the filter)
    I still have the problem of SOME of the DE blowing back into the pool. I vacuumed up on LOW SPEED all the DE that settled to the bottom. 2 hours later there it is again ? Like the DE is passing right through the sand ?
    My filter is brand new (well 1 month)
    Any idea where to start ?
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Sand filters get better at trapping debris as they get dirty but I would think it should catch DE even clean.
    -- Guy --
    May 2013
    North East Ohio
    959
    Yep I agree...
    So how do I figure out what is going on...is the next step to look for channeled sand ?
    Attached are the details of my filter innards...
    [attachment=0:32cxzx8o]Filter.jpg[/attachment:32cxzx8o]
    22,539
    Re: Problem with DE Blowing through Sand Filter
    Isn't this a new filter installation?
    You also state that you have glass bead media. Is that true?
    May 2013
    North East Ohio
    959
    Yes brand new and yes have the glass bead media.
    Hoping that is not the problem...but I guess I will be a good test study for once and all to know if this stuff is GOOD or ****.
    My PB just did it, without giving me any option.
  20. Back To Top    #20
    22,539
    The reason I mentioned it is that we've had reports of problems with alternate media in sand filters. They seem to either work well or not at all. With a new install you shouldn't be having any problems. Especially not channeling of the media. If DE will go through it, there's definitely something wrong with it.
