Thread: Bleach turned milky white in storage tank
    May 2011
    Long Grove, IL
    117
    I have been using a Stenner pump and 15 gal blue tank this year and I couldn't be happier with the results but I noticed when I started to refill my tank today that the little bit of bleach that was in the bottom of the tank was a milky white color. I have been careful to not let any junk fall into the tank and have only been using 12.5% from Menards. The pool is maintaining the correct level of chlorine so it doesn't seem that the chlorine is breaking down but I am at a loss to figure it out.
    I have emptied the remaining bleach and rinsed the tank with distilled water to clean it out.
    I am just looking for some ideas as to the cause since nothing came up in a search of this board or Google for that matter.
    Jay
    Jay
    28,000 gal in-ground hybrid pool with PacFab Superflow 100 sand filter witn VitroClean media, Intelliflo VS pump, Stenner chlorine pump, Raypak R336A Millivolt Natural Gas Pool Heater
    22,553
    Re: Bleach turned milky white in storage tank
    The white stuff is most likely salt or a little excess lye that's dropping out of solution. Cleaning it out is a good thing, but I wouldn't worry about it.
    May 2011
    Long Grove, IL
    117
    Bama,
    Thanks for the reply/reassurance that everything is A-OK.
    Jay
    Jay
