Thread: In ground pool vinyl liner is pulling away from cap.
    In ground pool vinyl liner is pulling away from cap. Where can I find the correct spline to put it back in place. I know you can use a hair dryer to heat and pull the liner into its proper position, but I need to find spline to hold it place.
    22,553
    Re: In ground pool vinyl liner is pulling away from cap.
    If it's what I think you want it's called Liner Lock. Your local pool store should have some.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Take some good clear photos of your liner and the receiver to the store so they can tell what size/style you need. There a couple of them. Most are the same but IIRC, a few are different.
    -- Guy --
