Thread: Hayward Pump won't spin
    So I went outside to clean out my filter basket, only to find the pump completely off and the breaker blown. I've had this issue in the past, so I reset the breaker and attempted to turn on the pump. Just a hum for about 5 seconds, then the breaker went again.
    I took the motor off of the pump housing, and I'm not able to turn the impeller at all with my hand. I haven't tried taking the back off and moving it with a wrench, but I wager that is my next move. I'm not sure what to do after that...
    20K gal, vinyl, 1 1/2 Hayward SuperPump, Hayward Perflex DE Filter (EC-65 or EC-75), In-Line Chlorinator, Kreepy Krauly
    22,550
    Re: Hayward Pump won't spin
    It's not unusual not to be able turn the shaft by hand. It is usually a little stiff because of the pressure the seal puts on it. It should, however, turn smoothly with a wrench.
    Guess I will go take the back off and have a go at it.
    I got the back off, and there is a lot of corrosion back there. I'm not able to get the screw off the capacitor to gain access to the shaft bolt. I'm thinking I'm pretty hosed here and will be looking at replacing the motor entirely.
    On a side note, I've watched a bunch of Super Pump related videos on YouTube trying to diagnose this issue, and it seems like all those impellers spin freely with little effort. Was just confused about that...
    I'd say if you can't turn the impeller by hand you probably have a bearing seized. You may be able to find a local electric motor shop that can rebuild it for much less than a new motor.
    16x32 Oval In-ground Vinyl, ~17,000 gallons, Hayward 1hp Superpump, Hayward S245T Sand Filter
    Worn out sand? sand-filter-expert-help-t30049.html
    Drain the easy way: cyanuric-acid-blues-draining-pool-t43843.html
    http://tftestkits.net/splash-page.html , pool-school/chlorine_cya_chart_shock , pool-school/shocking_your_pool
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by macgulley
    +1!
    My local guys, Virginia Pump, have saved my bacon more than once with a repair. These guys so much understand that pumps/pump motors are part of critical infrastructure (even for residential pool owners) that they mostly do same-day turnaround.
    Good luck!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
