Results 1 to 10 of 10
Thread: What is this chlorine test called?
    Aug 2011
    Central Valley California
    121
    What is the chlorine test called using the Basic test kit K-1000 that comes with the TF-100 test kit? Is that FC?
    23,000 gal IG Plaster 1989
    Purex Triton FNS Plus DE Filter Model FSNP 60
    1 Hp pump, Polaris 380 w/booster pump
    700 Gal Spa
    Laars Lite Heater T-F 100 Test Kit
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Re: What is this chlorine test called?
    That is the OTO test. Yellow test up to 5 ppm total chlorine. It's a down and dirty do I have some form of chlorine test.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    38,516
    Yup. It is a fool proof way to see if there is chlorine in the pool. It also does not bleach out at high FC levels like the pink DPD test.
    Aug 2011
    121
    Thank you. What does OTO stand for?
    700 Gal Spa
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    I believe that OTO test measures Total Chlorine (TC) which is the sum of Free Chlorine (FC) and Combined Chlorine (CC).
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by Bloomfield
    It's short for the name of the chemical dye. The names are as follows:
    OTO - Orthotolidine - in R-0600 Taylor reagent indicator dye
    DPD - N,N-diethyl-p-phenylenediamine - [EDIT] R-0870 Taylor indicator dye powder in the K-2006 or R-0002 liquid in the K-2005 [END-EDIT]
    FAS - Ferrous Ammonium Sulfate - R-0871 Taylor titrating reagent
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Orthotolidine
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Quote Originally Posted by chem geek
    DPD - N,N-diethyl-p-phenylenediamine - R-0003 Taylor indicator dye
    Color me wrong then. I was thinking the DPD was the powdered Taylor R-0870.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    [quote=Charlie_R]
    Quote Originally Posted by "chem geek":hor6s0ek
    Color me wrong then. I was thinking the DPD was the powdered Taylor R-0870.[/quote:hor6s0ek]
    It is. He is just talking about the indicator dyes and Titrant.
    Essential Links:
    Mar 2007
    San Rafael, CA USA
    12,082
    No, I was wrong. The R-0003 is potassium iodide for the Combined Chlorine (CC) part of the test. The DPD is powder in the R-0870 of the K-2006 or is in the R-0002 of the K-2005. I've corrected my post above.
