Results 1 to 15 of 15
Thread: TF-100 Test results - Brand new IG fresh water
    Jun 2013
    Southern Ohio
    86
    I recently built a DIY that is getting close to the concrete decking being poured. The liner was installed and filled with water about 2 weeks before all the plumbing was done and the pump running. In that time, I added about 1/2 gallon of 7.8% chlorine from bleach every evening. Once I got everything done and set up, I let the pump run for about 48 hours on low speed while adding a gallon of bleach in the evenings because the chlorine was very low still. I also had 0 CYA. 2 nights ago I put 6lbs. of granulated stabilizer in the skimmer. I put 1 gallon of bleach in it that night and last night and tonight (24 hours later) these are my readings:
    FC 5
    CC 0
    TA 120
    PH 7.2 I have the deck jets on now to help aerate?
    CYA 30 - This will mostly likely increase due to the fact stabilizer was put in only 2 days ago
    CH 230
    The water looks pretty clear and you can easily see right to the 5' bottom when you stand over it. When you look across the other side out of the pool you can't really see anything, but I also have the black granite liner. The problem is, it just doesn't have that "sparkle". When you are underneath the water, you can barely see 2 feet in front of you. This is the first pool I've built and maintained. All recommendations are greatly appreciated. On a good note, the chlorine level looks great considering it was added 24 hours ago. This is a pic of the water I took yesterday:
    [attachment=1:22pixybc]image (5).jpeg[/attachment:22pixybc][attachment=0:22pixybc]image (6).jpeg[/attachment:22pixybc]
    18x36 Lagoon vinyl IG DIY sport bottom 3.5-5-3.5 18K gal. Hayward Tri-Star 1 1/2 HP 2 Speed, Hayward 27" 350lb. sand filter, Hayward Aquarite w/ T-15, 1 skimmer, 2 returns, 2 step jets, 4 deck jets, 1 waterfall, TF-100
    38,524
    Re: TF-100 Test results - Brand new IG fresh water
    First, I would guess your volume is closer to 18k gallons ... and the 6 lbs of stabilizer should get you to around 40ppm.
    All in all your numbers look good. You could try an OCLT to see if anything may have started in the pool in the early days with no filtration. But, it could just be that you need to run the pump a little more to filter the debris.
    Looks pretty sparkly in your pics though
    Jun 2013
    Southern Ohio
    86
    Thank you! Do you think I should run the pump on low speed 24 hours a day for the next few days? That's nice, I just noticed under the pump I have a constant drip between the pump and motor. Brand-new Tri-Star. Unreal! Definitely not coming from the pipes dripping down either.
    38,524
    Definitely get that leak fixed before the bearings are damaged.
    What do you use for a cleaner? You could try the pump on low for 24/7, but if the flow is not enough to stir up the bottom and you do not use some sort of cleaner, then the dirt will settle and get stirred up the next time you swim.
    Jun 2013
    Southern Ohio
    86
    Ha! Pole and a brush for now! Been brushing the pool every couple of days. Any recommendations on what to use?
    38,524
    Well, that could certainly be your biggest problem.
    Depends on the type you want (suction side, pressure side, robot, hand vacuum) and the $$$ you want to spend.
    If you do not have a dedicated pressure side port, then that option is out.
    If you do not have a dedicated suction port, then you would have to put the hose in the skimmer and thus lose the ability to skim at the same time, plus they may not work on low speed
    Robots are nice as you do not need the pump on, but they are spendy.
    Hand vacs are cheap, but more work.
    Jun 2013
    Southern Ohio
    86
    Sorry, I should have went into more detail. I plumbed in a dedicated suction port about 6 feet from the skimmer. The pole and brush has the hose attached to it. That's what I've been using.
    38,524
    Oh, so at least you have been vacuuming
    So the 2 I had considered for a suction cleaner are the Polaris MX-8 and The Pool Cleaner. Supposed the PC can run on lower flow rates than just about any other suction cleaner, so there is a chance it could even work on low speed for you if you diverted all the flow from the suction port. Alternatively, if you had to run on high, you could keep more suction from the skimmer since the cleaner does not need as much flow. I would lean toward the PC.
    Jun 2013
    Southern Ohio
    86
    Thanks. I did the OCLT last night but I didn't add any chlorine. I just used the number from last night which was FC 5. That was after 24 hours of adding chlorine. So, this morning would have been another 12 hours and I tested it at FC 4. This good? I figure I'll add a little chlorine this evening according to the pool calculator.
    38,524
    At that low off an initial FC, it is hard to say if you passed. The 1ppm criteria is based on stating at higher FC levels closer to shock level. But you also did not test at night, so may not have lost all 1ppm overnight.
    Jun 2013
    Southern Ohio
    86
    I see. What level FC should I bring the pool to? Do I just put that much chlorine in one evening or bring it up to that level over a few days? Thanks for your help.
    38,524
    I think I misread, you did test the 5 last night and the 4 this morning, but I would be happier if you only lost 0.5ppm. Tonight I would target 10ppm (still before shock level), and test an hour after adding it. Leave the pump on and test in the morning.
    Jun 2013
    Southern Ohio
    86
    Want to make sure I do this right... This evening pour about 1 3/4 gallon of 6% chlorine according to the pool calculator, wait about 1/2 hour, then test to ensure I am close to 10? Then, run pump and test in the morning?
    38,524
    If you can I would wait an hour after adding bleach before you test after dark just to make sure it is mixed. But you got it.
    Jun 2013
    Southern Ohio
    86
    Will do. You guys are awesome and truly appreciated.
