Thread: Building new Pool need pump recommendations
    Hey guys,
    About to build a 30x14 pool around 16000 gallons. Pool has 3 water sheers and 2 ledge bubblers. No spa. Will have 2 inch piping.
    Builder is giving me options on pentair equipment. Is currently quoting 3hp inteliflo. Would this be the be the most efficient way to go?
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Building new Pool need pump recommendations
    It takes energy to move water and the more water you move, the more energy it takes.
    The most efficient way to pump is to eliminate the water features and bubblers but I suspect you don't want to do that. However, I doubt you will be running them all that much when not using the pool so maybe the efficiency doesn't matter so much.
    A VS pump stays efficient at most all speeds so it allows you to adjust the flow rate for the features used. Having a second pump is not really any more efficient and in some cases can be less efficient.
    Mark
    38,521
    Which pump are they recommending? I am not aware of a Pentair VS pump that is only 2HP. The Intellifo is a 3HP pump I thought ... unless it is the i1 which is identical, but with software limiting the maximum output.
    If it is the i1, I would suggest getting the regular VS instead in case you need the extra power.
    I'm sorry I meant the 3hp inteliflo. That is what he is recommending for the whole pool.
