Thread: Basic question for Stenner pump setup - tube into tank?
    Jun 2013
    Austin, TX
    70
    I have the pump and a 15 gallon tank with a lid and otherwise solid top. Is there any particular way to insert the tube into the tank? I went to Home Depot to get a 1/4" (I.D.) rubber grommet or bushing - no luck. Local specialty plumbing supply store - no luck. There are plenty of wholesalers online, but I can't find anyone local in Austin. I was not expecting to get hung up on this part! Any suggestions? Thanks in advance!
    12k gal IGP/Spa, gunite, Jandy 2HP ePump VSP, Jandy CL 460 Cartridge Filter, LXI400 Heater, PebbleSheen, Polaris 280, stenner 45MPHP10 auto chorine feeder
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Re: Basic question for Stenner pump setup - tube into tank?
    If your looking for a grommet suggest you go to a hardware store that has a good nut and bolt selection. They'll often have ancillary items like grommets.
    Just did a search on Google for "nuts and bolts Austin TX" and store called the Austin Bolt Co comes up that has lots of good Yelp reviews.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Jun 2013
    Austin, TX
    70
    Awesome, thanks!
