Thread: help drain plug broke off
    Jul 2011
    phoenix
    133
    I was cleaning my filters today and decided to throw some lube on the pumps drain plug. After doing do I overtightened it and it snapped off with the plug inside the threads Anyone have any suggestions on how to remove it without damaging the threads?
    13k IG pebble pool w/waterfall, 1hp whisperflow pump, pentair ccp320 cartridge filter
    Circupool SI45+ swg
    TF100 +speed stir Taylor 1766 salt test
    Jun 2013
    Huffman Tx
    190
    Re: help drain plug broke off
    heat tip of screwdriver and melt in a slot on the plug , then cool screwdriver and unscrew plug
    Jul 2011
    phoenix
    133
    **** should have thought about that, Talked to a mom and pop pool store and guy suggested tapping it with a flat head then unscrewing it. Worked after several attempts and 2 different size screwdrivers. Now the hunt for a replacement plug locally. Thanks again for the tip I think that would have worked a **** of a lot easier
    Circupool SI45+ swg
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Try a cork until you get the right plug. Go to a local craft store or maybe HD and get a bag of assorted sizes for a buck or so. After you cram it in, you might have to get it out w/ a cork screw.
    Why this suggestion? The service that closed my pool one year somehow removed a plug from my heater & stripped the threaded socket in the process. No reason for them to remove it in the first place and now the plug won't screw back in. Can't isolate the heater - filter to heater to pool only - and water is pouring out the hole. Anxious to get the filter running, I grabbed a bag of corks I had and gave one a try. I, of course, intended to promptly do a righteous fix, but now, 5 years later, the cork is holding fine.
    Good luck!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
