Thread: What is the formula underlying the Pool Calculator?
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    95
    As my pool volume doesn't change, I thought I could create a spreadsheet using the formula in the pool calculator. It would be a grid - along the top is my target FC along the side is my current FC. Each cell would have the amount that I need to add. I could then print it off and put it in my test kit box, and that way i can easily look up what I need to add.
    My question then, is - what is the formula that tells you how much bleach to add to get from actual FC to your target FC?
    18k vinyl IGP, Sand Filter, EasyTouch Control Sys, Pentair Intelliflo, Intellichlor IC 40 SWG, Rheem Heat Pump.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: What is the formula underlying the Pool Calculator?
    Someone just posted that in the "Deep End" forum. It will change based on several factors, but you'll get a feel for it and not even need a sheet in time.
    Essential Links:
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    95
    OK thanks - I see it now... Here http://www.troublefreepool.com/bleac...ns-t69102.html
    Bit more complex than I imagined!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yea, but honestly you will develop a really good feel fow how your pool reacts to additions. Promise.
    Essential Links:
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Is it possible to get Boric Acid added to the adding effects section at the bottom of the calculator?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by bobodaclown
    Not likely, if it isn't there, the people who own it now do nothing with updating it the last I heard. Perhaps someone knows something more recent.
    Essential Links:
