Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Upright rubbing finish of pool wall
    Makdaddy's Avatar
    Jul 2012
    Springfield Illinois
    119
    Well I noticed yesterday that the sides of the uprights appear to be rubbing a line (Vertical) into the finish on the pool outside walls
    Almost all of the uprights have done this
    I can only expect its from the walls flexing???
    there is no groove its just rubbed the finish off, like a scuff
    So how paranoid should I be?
    --- Greg----
    24 x 54 Round Cozumel AGP with Grand Entrance Step 14500 Gal
    Running ntex Krystal Clear Saltwater System with E.C.O.
    A/G Cristal Flo II Sand Filter Tank w/ 2HP, 2-Speed Dynamo pump -Zeobest
    TFT Test Kit---Gorilla Floor and Foam Pool Cove--Half Deck
    Makdaddy's Avatar
    Jul 2012
    119
    Re: Upright rubbing finish of pool wall
    Couple of pictures
    --- Greg----
    Jul 2013
    NH
    86
    Could you run a small bead of silicone caulking between the gap to stop the abrasion? Might do the trick.
    Mike
    18' Sharkline Oceanic
    Gorilla Pad
    Foam cove
    Confer 7200 ladder
    TF-100
    Use DE for your filter? DO NOT use anything but POOL GRADE DE!
    Makdaddy's Avatar
    Jul 2012
    119
    Doubt it
    I would think it would rub that as well.
    Im just perplexed as too why this started in the first place
    --- Greg----
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Your in Illinois so you get pretty cold winters correct?
    I'd bet it's because there's not much room between the decking and the post, I'd bet that your getting a bit of movement between the two during winter freeze/thaw.
    I left about around 1 inch between my deck and pool, 3 years later I have noticed a bit of movement.
    Jul 2013
    NH
    86
    Oh, I see. I thought your concern was over the finish potentially wearing off and corrosion following. No idea if the rubbing is cause for concern from a larger structural issue standpoint. Still might not be a bad idea to put something in there before the finish wears through.
    Mike
    Gorilla Pad
    Foam cove
    Confer 7200 ladder
    TF-100
    Makdaddy's Avatar
    Jul 2012
    119
    Quote Originally Posted by cramar
    Well then deck is 1 month old
    I just took those pics in that area, the other posts that dont have any decking around them are also doing the same thing
    I emailed the company I got the pool from, Ill wait and see what they say
    --- Greg----
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    My deck is very similar to your deck. I just added more decking to it and while I was working on it, DD was swimming. I had no idea the walls and risers moved so much when she played in the pool. I think your deck is too close to the riser and possibly the walls.
    -- Guy --
    Oct 2012
    Central Ohio
    180
    It's not caused by the deck.It's caused by your top plate not resting on the steel stabilizer rail under your top rail.(theres a gap between the top plate and rail i'd guess about 3/4")Look under your top rail at a spot where one of your uprights is rubbing,you'll see what I mean.
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Not sure if you have any steel parts in your pool (other than the wall) but I don't in mine. Mine are all resin.
    This is my pool and deck. I took these today and the deck has been in place for about 7 years.
    -- Guy --
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Now that I see what i posted, the first (top) shot has my new section at the bottom. The bottom three boards are "new" (sat in my yard for a year before being installed). I don't remember making that cut as close tot he riser as it is in this shot. I tried to leave a pencil's diameter of room between the pool wall and risers and the boards. I used a pencil as a spacer. It seems the carpenter I hired for the main deck used a pencil for all of the spacing on the deck.
    -- Guy --
    Makdaddy's Avatar
    Jul 2012
    119
    Quote Originally Posted by Makdaddy
    Couple of pictures
    The rubbing goes all the way up the post.to the top
    Thats whats odd, I would, think if the deck was the issue it would bind it down low.
    --- Greg----
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    The wall is going to move as a single unit and not flex. I wonder if its possible the manufacturer missed a layer int the coating process
    -- Guy --
    Oct 2012
    Central Ohio
    180
    Did you look at the gap between the steel stabilizer ring and the top plate? The gap allows the upright to move(when your swimming) not only in and out but left to right also,causing your scuffing.Ever notice how your top rail is not completely flat but is slightly "scalloped" in the areas where the side wall is scuffed.It's easier to spot if you stand on one side of the pool and look at the opposite side.You can see it in the 2nd photo you posted.(vertical post is the high point)
    Rob
    SWCG,Uni-bead liner
    Borates
    Makdaddy's Avatar
    Jul 2012
    119
    Wow
    yesterday I really found the real issues
    it finally got up into the 90,s I walked out of the garage and saw the upright by the deck leaning backwards the top plate completely off the rim of the pool, I walked around the pool and found 2 more uprights not connected to the top rail.
    I freaked out, my wife told me to calm down, and I finally did.
    called the pool builder, but he has not called me back yet.
    I told my wife that we will probably have to drain the pool to fix this, she says im crazy and over reacting
    --- Greg----
    Makdaddy's Avatar
    Jul 2012
    119
    Quote Originally Posted by CB
    I always thought that was not right
    I see you have the same pool
    Can you post a picture of yours
    --- Greg----
    Oct 2012
    Central Ohio
    180
    I can take a couple pics,it won't be today.The reason your having trouble is they redesigned the length of the uprights.They were having trouble with settling issues,so they made the uprights longer.The problem with that is if you install the pool correctly the pool settling will be minimum and you will find that gap I was talking about.If you look in the "manual" they list pavers for the verticals as an "optional".The other problem is the top rail is resin & the verticals are resin,they didn't allow enough expansion room for of the type of plastic they used..Did they look at your pool yet?
    Rob
    SWCG,Uni-bead liner
    Borates
    Makdaddy's Avatar
    Jul 2012
    119
    Rob
    No one has contacted me
    Ill be calling the pool store today.
    Thanks for the info
    The installer did put pavers or landscape blocks under the posts
    --- Greg----
    Jul 2013
    NH
    86
    Greg, hopefully your issue will be solved soon.
    Am I the only one seeing the optical delusion in some of those pix? Look at the radius at the bottom of the photos as defined by the decking. Now look at the top rail radius. Spooky! Do do do do Do do do do.....
    Mike
    Gorilla Pad
    Foam cove
    Confer 7200 ladder
    TF-100
  20. Back To Top    #20
    Makdaddy's Avatar
    Jul 2012
    119
    Quote Originally Posted by NHfloater
    Thanks
    time will tell
    I sent pics to USA POOL PROS the company out of Chicago I got the pool from
    He denied any issues with the uprights
    But he will try to warranty the uprights off of the pictures
    So I wonder if they will be shorter?
    --- Greg----
