Page 1 of 4 1234 LastLast
Results 1 to 20 of 62
Thread: Need to replace pump - recommendations welcome
    Aug 2010
    Dallas, TX
    4,052
    I know how to keep a pool clean, but no knowledge about pumps at all. Attached is a picture of my existing pump. It's squealing and howling (both) very badly, it is most certainly going out. I guess 12 years of use was too much for it.
    My pool specs are in my sig line.
    I pay approximately 11.5 cents per kwh. Don't know if going to a 2 speed will save significant funds, but I am willing if it will. I'm currently on about a 7 hour run time to keep FC up with the SWG.
    Pool has one skimmer near the middle of the pool, and 4 returns at the shallow end, all pointed toward the back of the pool.
    I also don't know if I should replace just the pump, or replace the impeller at the same time.
    It is wired 220v, if it matters.
    Returns are all along this wall, skimmer can be seen on left. There is a main drain in the floor, I still don't know if it is hooked up though.
    May 2009
    Youngsville NC
    395
    Re: Need to replace pump - recommendations welcome
    You could replace just the motor with the same HP and SF ratings, or any other motor where HP * SF = 1.65. If you go this route, replace the seals between the wet end and the motor at the sametime.
    The other option is to just replace the whole pump with a new one. Given the size of your pool, I'd look for a new pump about the same size (the Pentair Whisperflo as an example).
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Man I hate to hear that Robbie! Something else to eat into the re-finish funds eh? I'm only in reaearch mode with pumps so I can't offer much. Any chance its just a shaft seal or something similar? I bet one of the pump guys will be along shortly to offer more. Good luck Pal.
    Essential Links:
    Aug 2010
    Dallas, TX
    4,052
    I don't mind replacing the pump since it's so old. It seems most my pool owner friends only get 3-4 years out of their pumps!
    Smykowski's Avatar
    Sep 2011
    3,065
    Any chance for a rebuild? Maybe Mark can chime in if it's worth redoing bearings and seals on a 12 year old pump.
    Aug 2010
    Dallas, TX
    4,052
    My math stinks when I'm multitasking. That pump is 22 years old. Date code is 1991.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by RobbieH
    This makes you a great canidate for a 2-speed assuming that it would move enough water to activate your swg flow switch on low. Think about it this way, running for 7 hours on low would use 1/4 the energy and would still likely keep you pool water clear.
    Do you have a model number for the pump (what you took a picture of just shows the motor details I think)?
    Aug 2010
    Dallas, TX
    4,052
    I'm going to correct myself again.
    Without the SWG, I can run just 5-6 hours to keep the pool clear. With the SWG in line, I must run 8-9 hours, or more, to keep the FC up to 4. I have CYA of 70 (need to bring it up a little more), I just figure with the pool being so big, the amount of leaves I get every day, and the full sun, it just takes a lot of chlorine to keep the FC at level. I'm still doing some adjustments on the SWG (percentage, pump run time...) as I just got a new controller (had a board failure) and this one seems to either be acting differently than the old one; or, although unlikely, I have not properly held FC up while the SWG takes over (brought FC up to 8 when SWG came back up, was holding at 6 during outage). Doing daily checks to determine which. I don't think I currently have a flow problem, it's just horribly loud.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    So with a 2-speed motor and the same pump curve as you currently have, you would likely need to run on low for ~10 hours to keep the pool clear which is just slightly more than the 9 hours to keep the pool chlorinated. Again yours is a good case for a 2-speed.
    I am not sure if you missed my question above about the pump model number (I edit my post)?
    Aug 2010
    Dallas, TX
    4,052
    The model is on the sticker. 1103665400. A Google search finds this:
    http://www.aqua-man.com/motorManDetails ... orID=18878
    Equivalent/replacement is AO Smith B854
    Aug 2010
    Dallas, TX
    4,052
    Does this look like a viable replacement? Does anyone know if I can wire my SWG into the pump's timer? Will the SWG run on both high and low?
    http://www.poolplaza.com/P-AOS-B2983T-5005.html
    These guys are just up the road from me, would be easy to go pick it up.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Replacement is AO Smith B854
    That looks right to me...also cross referenced here: http://www.inyopools.com/Products/03000017000395.htm
    Yes, but that is really expensive. Do you know if you are wired for 115 or 230 volts? All the 2-speed motors I know of at that size are 230 volts.
    Much cheaper here: http://www.inyopools.com/Products/07501352062874.htm and http://www.poolsupplyworld.com/Centu...30V/B2983T.htm
    I am not sure about this. You need to look at the minimum flow rate for the swg.
    Aug 2010
    Dallas, TX
    4,052
    Yes, as noted, I'm wired 230. I'm getting 116v per leg, I tested this yesterday as I was checking grounds and such in my old wiring system.
    That is a lot cheaper. I searched INYOPOOLS before, but it pulled up the 2hp version without me realizing it. I'll call them and ask about the wiring.
    I am not too concerned about the minimum flow of the SWG, I need to wire the SWG into the pump's timer so that it turns on and off. I'll see if I can find my minimum flow. It's a CompuPool CPSC48.
    One thing about going up to my local place is I can have it today, and there are no shipping costs. But that price difference with the right pump at inyo, is significant.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Inyo does charge extra for shipping, the other link, psw has it in the price ...but having it today is worth something.
    Aug 2010
    Dallas, TX
    4,052
    Or if something goes wrong, they are local.
    My current pump is still running, but boy it sure is loud. It makes a high-pitched squeal for the first 15-30 minutes at start-up, then it makes a "waving" grinding noise at all times.
    Aug 2010
    Dallas, TX
    4,052
    another question, think I'm ok just changing the pump end when it is all 22 years old?
    I found more numbers, the whole assembly is a Sta-Rite P2RA5F-125L
    Aug 2010
    Dallas, TX
    4,052
    And evidently I'm a D on this chart, but I don't know what that means to me yet.
    http://www.pentairpool.com/pdfs/duraglasDS.pdf
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    That is a long life for a pump, but if that part is still working well, I see no reason to change other than some newer designs may be a little more efficient. For sure your pump design is reliable.
    That pump curve shows that your pump is comparable to 3/4 hp full-rated pentair whisperflo, though the whisperflo appears to be more energy efficient.
    Aug 2010
    Dallas, TX
    4,052
    I still don't understand the full rated and uprated thing. Seems like some marketing garbage.
  20. Back To Top    #20
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It's a head scratcher for me too.
    Essential Links:
