Results 1 to 10 of 10
Thread: swimmer's ear
    swimmer's ear
    hey all...just a quick question.
    two of my four kids have just been diagnosed with swimmer's ear.
    am i doing something wrong witht he water? of is this just something
    that happens with kids. the pediatrician said that it shouldn't be a problem
    with the water...just that they don't get all the water out of their ears when
    they get out.
    anyone else having this problem?
    don't have current numbers but i test frequently and my ph and fc levels are right
    on the money...
    IG 17x26x36 Designer Ell
    vinyl liner
    Hayward c-3000 (4) cartridge filter
    Dolphin diagnostic pool cleaner
    Feb 2008
    Ohio
    156
    Re: swimmer's ear
    I believe this topic was discussed awhile back
    but, since I read the old messages I started using the swimmer's ear medicine for me and kiddos...so far so good (my daughter has super sensitive ears) so I wanted to make sure all that water was coming out of her ears.
    the medicine is about $4 and i get it at walmart and now the kids are trained to come get their ear drops after swimming
    chris
    30-40yr old prehistoric IG gunite 20 X 40 approx 30000gals
    now with new cool blue Diamond Brite and blue waterline tile (looking good for 40yr old pool)
    new Hayward 244T sand filter, 3/4 Hayward pump, Jandy heat pump
    pool skim (love it)
    May 2008
    North Carolina
    79
    Re: swimmer's ear
    I had swimmer's ear every year of my life until I was 25. Now it is just every other year My two brothers never had it, and they swam in the same ocean, lakes and pools that I did.
    It just happens with kids, and not all kids. If they get it again, and you know they are suceptible, just try to be preventive about it. The swimmer's ear drops at the store help some.
    It is extremely painful. And there is nothing much you can do about it. When I was older a little alcohol, numbed the pain, but it has to be ingested orally for that to work
    16 X 34 21,000 IG Vinyl Liner
    1 1/2 Hayward SuperPump
    New Sand Filter (had cartridge - hated them)
    Anemone's Avatar
    Jul 2007
    Northeastern Maryland
    48
    Re: swimmer's ear
    Sorry to hear about the kid's ears. Swimmers ear can be miserable.
    Well, in my case, it can just happen. I used to get it from just showering. Ear plugs are the best preventative but I personally hate them.
    Necessary Caution: I am not an MD and I don't even play one on T.V. Always check with your doctor first before putting anything into the ears and never use the following on ears with perforated ear drums or those with tubes!
    That said, my favorite preventative is to tip my head to the side and put a squirt of rubbing alcohol into my ear. I pull on the ear lobe to get it to run way in, hold it for a few seconds then tip my head over to let it run out onto a towel. Repeat with other ear.
    Some people use vinegar, others use a mixture of half vinegar and half rubbing alcohol, but I like plain old rubbing alcohol best. It dries up the water and the moisture is what the the little bugs need to grow. Vinegar is mildly acidic so it changes the pH and makes it hard for the bugs to grow too.
    I used to get horrible swimmers ear but I have been doing this for 40 years and now I never have a problem. If I forget and my ear starts to become uncomfortable, I start doing it several times a day and it goes away. I also do it to my son and he has never had a problem with his ears.
    Good luck. Hope the kids feel better soon!
    22,000gal IG, Lazy L, vinyl pool - 1.0 HP Pentair Whisterflo - DE filter - Blue Pearl Robotic cleaner - Glowbuoy - BBB only!
    Re: swimmer's ear
    Ben Powell's old PoolForum.com used to have a page on swimmers ear. I can't bring it up directly any more, but here's a Google cached page.
    -Steve, Westford, MA; 31,326 gal 21' x 41' IG Imperial 1000 Series vinyl pool
    96 gpm Hayward DE-4800 filter,1.5HP,3hrs/day,$0.72/hr;TF100 test kit, Borate & Salt strips
    revstriker's Avatar
    Apr 2008
    Texas
    117
    Re: swimmer's ear
    My daughter got swimmers ear last year (she was 5 year old). Very painful. Dr. reccommended the swimmers ear drops that you can get from the drug store. It worked great for her (and still does).
    10K White Plaster Pool Built in 2007. Hayward Pump and DE Filter, Hayward Navigator, Liquidator (Removed due to issues), Solar Blanket, BBB user.
    Jun 2008
    Central VA
    17
    Re: swimmer's ear
    FYI -- Those drops you buy at Walmart for swimmers ear is just plain old rubbing alcohol. Check the label and you could save about $3.00.
    Brandy in VA
    -- 16' X 48" Intex Metal Frame Pool
    -- 5061 Gallons
    -- 1000 GPH Intex Pump
    -- BBB Believer
    Anemone's Avatar
    Jul 2007
    48
    Re: swimmer's ear
    Quote Originally Posted by brandynva
    Yep! I think almost all the brands contain either alcohol or a mixture of alcohol and acetic acid (vinegar) and they charge you big $$$.
    Feb 2008
    Ohio
    156
    Re: swimmer's ear
    Active Ingredients: contains: Isopropyl Alcohol (95%) (Ear drying aid)
    Inactive Ingredients: Anhydrous Glycerin (5%) (base)
    this is whats in swim ear products....yes, the isopropyl alcohol is rubbing alcohol but, its the glycerin thats in it that helps not to over dry your ear drum....i read somewhere that if you used 100% rubbing alchohol you would damage you ear drum.
    i will keep to the store bought products for our family.
    chris
    pool skim (love it)
    Anemone's Avatar
    Jul 2007
    48
    Re: swimmer's ear
    Quote Originally Posted by chrisa
    chris
    What did you say? I can't hear you......
    All joking aside, alcohol will not hurt a normal ear. Many doctors recommend its use as a preventative against swimmer's ear. The glycerin that is put into the OTC drops is actually mildly irritating and hygroscopic. It has three hydrophilic alcoholic hydroxyl groups which attract water from the surrounding environment, so it actually drying the ear along with the alcohol. It is fine to use, it just costs more than plain old isopropyl alcohol.
    Now, if the ear is infected, then you need antibiotic drops, not alcohol. It is also important that alcohol never be used in an ear with a ruptured eardrum.
    The main thing is to keep ourselves and our families healthy so we can enjoy our pools!
