Thread: would a sand filter/ SWG combo be overkill?
    Hi,
    Would a sand filter/ SWG combo like this:
    http://www.amazon.com/Intex-56677EG-Fil ... d_sbs_lg_5
    or this:
    http://www.amazon.com/Intex-Krystal-Fil ... roduct_top
    be way overkill for a 1000 gallon plastic stock tank kiddy pool?
    I'm looking for minimal maintenance here and am willing to over do it if it makes things easier.
    Thanks!
    Erin
    Erin
    10' x 30 Intex Easy Set Pool 1,018 gallons, Intex Krystal Clear model 637R / 56637E 1,000-Gallon Filter Pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: would a sand filter/ SWG combo be overkill?
    linen edit: I made a mistake and meant to say recommend againt getting the all in one design...sorry about that
    Quote Originally Posted by satsitananda
    imo, yes. I would just follow something similar to this: http://www.troublefreepool.com/pool-...ary_pool_guide
    By the way, I strongly recommend against getting the combo swg/pump/filter units. The swg and pump never fail at the same time.
    270 bucks isnt that expensive imo. I think it would be a neat project.
    http://www.apartmenttherapy.com/summer- ... tank-90793
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Hi, if this is for the pool listed in your signature it should be fine.
    Love TFP? Become a
    TFP Supporter!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Sorry about my mistake above (which I have now corrected)...if it wasn't clear, I strongly recommend against getting the swg/pump/filter all in one, since the swg and the pump will never fail at the same time.
    Thanks for the replies... It would be for a 1000 gallon polyethylene stock tank... slightly smaller then the intex pool I have now...
    good to know about combined units.
    Erin
