Results 1 to 13 of 13
Thread: Nature soft board flashing low salt
    Sep 2012
    Saugus,Ca
    40
    I have a Nature soft by Pebble tech system and its flashing low salt. I replaced the T-cell last year and system has been running great! Just not sure how much salt I should add. Our pool is roughly 16-18k gallons. Thanks for any help!
    16'x34' sport shape pool with raised waterfall jaquzzi,Intelliflo VS pump,Hayward DE filter,NatureSoft(Pebble Technology)salt board,Hayward H250 heater,Hayward T-15 cell
    22,550
    Re: Nature soft board flashing low salt
    The only way to know for sure whether the cell is the problem or not is to have it tested. Local pool stores can usually test it for you.
    When was the last time you cleaned the cell?
    Sep 2012
    Saugus,Ca
    40
    I clean it every 4 months. The board says its still generating,but flashing low salt.
    Sep 2012
    Saugus,Ca
    40
    Bump up,still looking for a idea of how much salt to add. Thanks
    38,295
    Is there build-up every 4 months? If not, then you are shortening the life by cleaning it.
    Tell us your current salt level via independent testing (not what your SWG says, but if it does say tell us that too) and your pool size and then we can suggest how much salt to add.
    Sep 2012
    Saugus,Ca
    40
    Thanks Jason! What's a good way to test the salt level? Thanks again!
    Aug 2010
    Dallas, TX
    4,052
    I prefer this test. I have found it far more accurate and reliable than even the best test strips.
    http://tftestkits.net/K-1766-Taylor-Salt-Test-p31.html
    It is also extremely easy to read.
    Otherwise, either Aqua Chek test strips, or your pool store.
    Sep 2012
    Saugus,Ca
    40
    Thanks,and sorry for sounding like a complete rookie
    38,295
    Quote Originally Posted by Dunerking
    No worries ... we were all there once
    Just go back and look though some of the early posts from any of us ... on 2nd thought, don't do that
    Aug 2010
    Dallas, TX
    4,052
    Please don't!
    Sep 2012
    Saugus,Ca
    40
    Cleaned the cell,it's amazing how the calcium builds up in 3-4 months. Tomorrow I'll pick up a salt test kit. Thanks again!!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Post a full set of test numbers and we may be able to help you reduce the buildup. At least TA, ph, CH, cya, borates (if you have added them in high concentrations), salt
    Sep 2012
    Saugus,Ca
    40
    Will do,thanks!
