Thread: Fluccolant overdose
    Aug 2013
    Greece
    4
    Fluccolant overdose
    Hi!
    This is my first post to this forum.
    A concrete pool has been overdosed with fluccolant and the water became cloudy. Could you please help me with this situation? In which way can i make the cloudiness disappear?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Fluccolant overdose
    Welcome to tfp, miltos
    We don't generally recommend flocculants, and what happened to you is one of the reasons why. I would just vacuum to waste anything that is settled on the bottom then keep your pump/filter running 24/7 and brush the pool a couple of times daily. If it doesn't start clearing up in a day or so, then post a full set of test numbers: http://www.troublefreepool.com/pool-...efore_you_post
    Aug 2013
    Greece
    4
    Thanks for the reply.
    I had already increased the filtration working hours and observed significant improvement in a couple of days.
    Was the improvement due to the intensive recirculation-filtration, or would it have occured anyway (after some time)?
