Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Brand New Pool Startup
    Jun 2013
    Austin, TX
    70
    Hi - I have PebbleSheen going in tomorrow (Monday), acid wash Tuesday, with fill immediately thereafter. I have read through the Pool School and forum and have the TF-100 test kit.
    My fill water is:
    TC 1.0
    FC 0.5
    CC 0.5
    Ph 7.5
    TA 200
    CH 180
    CYA 0
    My understanding is upon filling to address the chemicals in this order: Ph, CYA, FC
    1) Since my Ph is ok, nothing to do except monitor (If it drops I will aerate to try to lower TA some)
    2) Add stabilizer - Pool Calc for my 12k gallon pool recommends 48 oz granules, or 125 oz liquid - solid added using nylon, ok to pour liquid into skimmer
    3) Add bleach - Pool Calc recommends 81oz of 8.25% bleach - add through skimmer
    Any thoughts, comments, criticisms, or corrections are appreciated!
    12k gal IGP/Spa, gunite, Jandy 2HP ePump VSP, Jandy CL 460 Cartridge Filter, LXI400 Heater, PebbleSheen, Polaris 280, stenner 45MPHP10 auto chorine feeder
    30,431
    Re: Brand New Pool Startup
    Excellent!
    You have everything correct.
    Chlorine introduced through the skimmer is OK but really should be done very slowly so your equipment doesn't get a big dose. Pouring it in front of an active return will allow you to introduce it quicker and it disperses throughout the pool very fast....like 30 minutes.
    Jun 2013
    Austin, TX
    70
    Hi Dave - Yes, I was going through one of the threads after my post and noticed that error. Thanks for pointing it out and for the reply! John
    Since TA is 200, how long do you wait until you address it?
    30,431
    The pH will almost always rise naturally.....especially in a newly plastered pool. When you drive pH back down with muriatic acid, it will also lower the TA.
    So, as long as OP is not seeing his pH spiking too often, I would simply leave TA alone and let it drift down into range somewhat on it's own but with some help from the anticipated muriatic additions.
    It is certainly acceptable to lower it immediately using the process described in Pool School, but that probably isn't necessary in this case.
    Thanks. We are building a pool and I am in process of planning pool start up and we supposedly have water that is high in PH. This helps.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Telnet64
    Yep, I have some.
    Welcome to TFP first off and a hat's off to you for jumping in a educating yourself. Love seeing that. You're off to a fine start and it looks like it will come easy for you. PebbleTec and your builder may have startup procedures you have to adhere too for warranty issues, so make sure you are squared up on that.
    Most importantly, we love seeing pics of your new pool!
    Essential Links:
    Quote Originally Posted by Brushpup
    What he said. This is where you should imagine a cute gif that says "this thread is worthless without pictures." Ha!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by KenGood
    Ken ought to know...he may have more pics in a build thread than I've ever seen here. The amount he has posted so far is just about the perfect amount.
    Essential Links:
    Jun 2013
    Austin, TX
    70
    Thanks for the comments and I will get some pics to post.
    As a follow up question, I am considering using liquid stabilizer, but this is all I can find locally:
    http://www.intheswim.com/Pool-Chemicals ... nditioner/
    In the pool calculator, do I enter this as liquid stabilizer to determine how much to add?
    Thanks again!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    In Austin, you can easily find some at Walmart or Hardware stores that have pool products. At Walmart, it is HtH stabilizer/conditioner. It will be a 4lb container of 99% Cyanuric acid. In granular form.
    Essential Links:
    Jun 2013
    Austin, TX
    70
    Thanks, I have granules. For my startup I'm using liquid and the only liquid I could find is the "Instant Pool Water Conditioner" and I'm trying to figure out how much to add, since it's not explicitly in the Pool Calculator. There are some threads that mention it's ok to use this to add CYA, but I haven't seen the dosage issue addressed.
    22,553
    Liquid Stabilizer is listed in the pool calc. In fact it's in the CYA section so you don't even have to use the "Effects of Adding Chems" section.
    Smykowski's Avatar
    Sep 2011
    3,065
    In the second line of the CYA box on the Pool Calculator page it gives you the amount of liquid stabilizer to add. Those are oz. by volume.
    Jun 2013
    Austin, TX
    70
    Thanks, I wasn't sure that this product was the same as "Liquid Stabilizer". In reading other threads, itis similar, but not as acidic. I appreciate your clarifications.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    That's it.
    Just curious why you want to go to the trouble of finding liquid.
    Essential Links:
    Jun 2013
    Austin, TX
    70
    I have a child with a disability and it's preferable to get it in immediately vs trying to keep a sock hanging for a week.
    Jun 2013
    Austin, TX
    70
    Hi, the startup has been going well, been adding about 4-6 cups of 8.25% bleach per day. Also, pH has been drifting up to 7.8 - 8.0, so been adding MA per the calculator.
    Today I am at:
    FC - 2.5 (before adding bleach)
    CC - 0
    PH - 7.4
    TA - 80/90, this has been lower than I expected.
    I think I've read that the new plaster will push the pH up for a while. Is there a preference between Borax and Baking Soda to increase pH? I've read posts various posts about people using both, but also read something about not using Borax on new plaster.
    Thanks for any assistance!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Any pH increase from bleach is very temporary. Don't use Baking Soda to raise pH. It increases TA with raising pH much at all. Let the pH increase on it's own so your pool can reach equilibrium. Adjust down when it hits 7.8 by using MA.
    Essential Links:
  20. Back To Top    #20
    Jun 2013
    Austin, TX
    70
    Thanks, so 20 Mule Team Borax preferred to raise pH?
