Results 1 to 17 of 17
Thread: Cleaning a DE filter
    Chad628's Avatar
    Jul 2013
    San Francisco Bay Area
    99
    I took apart and cleaned my DE filter for the first time and had a question about draining the water from the filter. My filter sits on a concrete pad very close to the property line of my neighbor. When i removed the drain plug the water drained onto his property and flooded his flower bed killing some of his plantings there. Can anyone suggest a way that i can drain my filter and control where the water drains? The drain plug is about four inches above the concrete pad so it would be difficult to catch the water with a bucket due to low clearance and a tight space. Because of the orientation of the drain plug Its natural path is right into his flower bed. If i put the backwash valve in the backwash position would some of the water drain from that valve just from gravity with the pump off? I don't understand the plumbing of the filter very well so that may be a dumb question.
    Petaluma, CA., 11K gallon IG pool, white plaster, Nautilus FNS 36 sq. ft. DE Filter, Jandy 1.5 HP variable speed E pump, Pentair Booster Pump with Polaris Vac-Sweep 280 pool cleaner, Jandy Laars LX Pool Heater, Remodeled (new plumbing, plaster, tile, coping, variable speed pump) January 2013. 400 gallon Artesian Island Spa (Ozonator/Chlorine), TF-100 test kit, SpeedStir.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Cleaning a DE filter
    Add a cut off valve in place of the plug then run a backwash / discharge hose down hill from there to a more appropriate location. You can use a cheap thin blue style discharge hoses for this since the water is not highly pressurized (typically under about $20 online for 100 ft length, see amazon, ebay, or your preferred pool vendor)
    Ike
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Quote Originally Posted by Isaac-1
    Ike
    This is what I did with my DE filter. I added a 1 1/2" diameter 3" long nipple to the filter discharge opening and then added a ball valve to the other end of the nipple. I attached a clean out hose on the slip end of a fitting using a band clamp. The other end of the fitting screws into the open end of the ball valve. When I am ready to drain the filter I attach the fitting with the hose, lay it out where I want it to go and open the ball valve. You will need to flush the hose after draining the filter to make sure all the DE washes out.
    Love TFP? Become a
    TFP Supporter!
    Chad628's Avatar
    Jul 2013
    99
    Zea3 that sounds like a great solution. Thank you so much for that suggestion. Is there any chance you can post a photo of your set up?
    In your opinion would the following items work?
    http://swimmingpoolproducts.halogensupp ... d&filter=0
    http://swimmingpoolproducts.halogensupp ... |1266|1265
    Jul 2013
    Columbus, Ohio
    114
    I have what Zea3 suggested but you could do it a different way. I have the blue hose that was suggested with the band clamp. I also have a threaded fitting with a 90 degree elbow. I take the cap out that shows in your photo and screw the fitting in place. Since it is a 90 degree, I can point it left or right depending on how much I screw it in. That way I control which way I want the water to go. The hose is very flexible and can be laid out in a gentle curve as well.
    The ball valve lets you do this without draining any water out. With my suggestion you would have to dump the water in the filter on the ground first. Obviously, the pump is off. Hook everything up and point the hose where you want an turn the pump on.
    16,500 gallon, 18" x 38" Grecian; IG Vinyl, Hayward DE
    Chad628's Avatar
    Jul 2013
    99
    DorsalSpine where did you get that fitting? Could you point me to an example of one in a link? The 90 degree turn would be very useful for me. Thank you very much.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Here's one --
    http://www.plumbersurplus.com/Prod/Geno ... MgodMxIAEg
    Put a ball valve on the slip end, and you are in business.
    Jul 2013
    Columbus, Ohio
    114
    Quote Originally Posted by Charlie_R
    Here's one --
    That would be it. The ball valve makes this a much easier process long term. I have one as well. I was suggesting the 90 degree as a quick fix that wouldn't require any gluing. I found mine and similar ones with gentler angles at Home Depot. Any home improvement place (Lowes, HD) or a plumping supply house, or a hardware store should have something similar.
    Chad628's Avatar
    Jul 2013
    99
    In your opinion would teflon tape on the threads be sufficient to prevent leaking when the filter is under pressure?
    Jul 2013
    Columbus, Ohio
    114
    Quote Originally Posted by Chad628
    In your opinion would teflon tape on the threads be sufficient to prevent leaving when the filter is under pressure?
    Yes it would. However, I noticed that once the fitting snugged up the lack of tape wasn't a problem. I was in a hurry one day and didn't tape the fitting. For a drain that isn't under continuous pressure it should be fine. In your photo, I would put the cap back once I was done and just store the 90 for next time. Fittings under continual pressure should be taped and/or glued as appropriate.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If you want an all in one solution and don't want to stack fittings together you could get a Hayward SP729 valve which is designed for just this exact use with male threads on one side and hose barb connection on the other, costs about $20 online with shipping.
    Ike
    p.s. cheapest price I spot is $19 at amazon with free shipping
    Chad628's Avatar
    Jul 2013
    99
    Is 1 1/2 inches standard for DE filter plugs? I took a tape measure to mine and it looks more like 2 1/2 inches.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Go to your local hardware store that sells PVC fittings, and measure an adapter. I think you will be surprised at the size of the threaded portion.
    Nominal pipe sizes are generally for the inside diameter. Wall thickness accounts for the difference in thread size and inside size.
    Better yet, check out this chart. http://www.mcnichols.com/viewer.htm?pageCode=pipedims
    Thee you can see what I mean by "nominal" pipe sizes, as these closely follow what iron (threaded) pipe is.
    Chad628's Avatar
    Jul 2013
    99
    Thank you Charlie for explaining that to me. I have not worked with enough plumbing pipes and fixtures to realize how large the differences are for inside and outside diameters of pipes and fixtures. The 90 degree elbow you provided the link for and the Hayward SP729 ball valve that Ike linked me to will be a perfect solution for my problem.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If you get a 90 degree elbow and the Hayward valve I posted you will need to get a 90 with threaded fittings on both sides, most PVC 90's you find will be either slip fitting (glue) on both sides, or slip on one side and threaded on the other (male or female sides, but not both). Alternatively you may need to get a 90 that is threaded on one side, and a slip to threaded adapter to glue to the other side, and of course PVC cement (I suggest the blue rain or shine type) to glue them with.
    Ike
    Chad628's Avatar
    Jul 2013
    99
    My final solution. It works beautifully!
    Mar 2012
    Tampa Bay, Florida
    166
    Very nice and thanks for letting us know how it turned out.
    John (DIYer). Concrete, approximately 13,000 gallon in-ground pool with adjoining concrete spa. Approximately 40 years old. Hayward Super II pump for pool and legacy Anthony Sta-Rite bronze pump CF6 for spa, VA-26 filter,(2 sets), Rheem propane heater for spa. HASA Liquidator for pool.
