Results 1 to 13 of 13
Thread: Confused on timers.
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    Confused on timers.
    I've decided to install a timer so that I can run the pump less automatically. Originally I was going to just buy the plug in type, but found out that they are NOT designed for a 1.5hp pump motor.
    So I'm looking at hardwired timers. I bought one at Lowe's tonight on a quick stop and when I got home started reading about it. http://www.nsiindustries.com/Repository ... cSheet.pdf If I read this right, it won't work on my 1.5hp motor either.
    Am I reading the specs correctly? What kind of timers do you all use on 1.5hp pumps?
    27' Round X 54" Aqua Leader Sentinelle AGP, Vinyl J hook liner. 18,500 gal.
    Waterway 19" oval sand filter, US Motors EZBN25 1.0 hp 1.5 SPL Pump, BBB (Empty Aqua Smarte System connected, may use during vacation), Barracuda Zodiac 1500,
    Taylor FAS-DPD K-2006 Test Kit.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Confused on timers.
    I use an intermatic T101. It's hard wired in.
    Jeff
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Confused on timers.
    I think you will find the intermatic brand timers to be widely regarded as the best option out there, the specific model you need may depend on how you plan to install, etc.
    Ike
    Jul 2013
    NH
    86
    I use the T101R. The "R" suffix indicates the timer is housed in a weatherproof box. For me, it was cheaper to get that model vs a standard 101 and a weatherproof box to house it in.
    If you opt for an Intermatic timer and are planning on running multiple on/off cycles, buy some extra trippers as the unit itself only comes with one pair.....which I'll add is a total cheap out on Intermatics part. The timer itself is great and simple to setup/use.
    Mike
    18' Sharkline Oceanic
    Gorilla Pad
    Foam cove
    Confer 7200 ladder
    TF-100
    Use DE for your filter? DO NOT use anything but POOL GRADE DE!
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    The timer will be installed inside the house near the breaker box. So inside/outside doesn't matter to us.
    Do any of you have a 1.5hp pump motor? That seems to be my difficulty.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Mine is also inside, basement. How many volts is the pump.
    Jeff
    22,553
    While the Intermatic timers are the workhorses of the industry, in reality you only have a 1 hp motor or less. It's most likely a 1.5 spl rated pump. A lot of plug in timers will handle that. Just giving you options.
    Jul 2013
    NH
    86
    The 101 is rated for 40A. Even at startup I doubt there will be an issue.
    I was gonna put my timer next to my panel but I'm also using it as my code required shutoff. The main issue I had with placing it in the basement was if the timer was OFF and I wanted to vacuum, it would require trips back and forth to the panel. I'm lazy. Something to think about if you are too.
    Mike
    Gorilla Pad
    Foam cove
    Confer 7200 ladder
    TF-100
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    IIRC, when you place the timer in the basement, you will need a shutoff for the power within sight of the pool. NEC code, if i understand correctly.
    -- Guy --
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    brmommy:
    I have a 1.5 HP pump with a Service Factor of 1.1 resulting in a Service Factor HP (SFHP) of 1.65. I use an Intermatic T104R201 mechanical timer. Here is the specs faceplate:[attachment=0:3ixfdi61]timer_specs.jpg[/attachment:3ixfdi61]
    Feb 2013
    West TN
    16
    The specs on the timer you have says that it is good for up to a 2HP motor if it is wired for 240V. If yours is wired for 240V, you should be fine. Also the timer enclosure is a Nema 3R rating, so it is fine to be installed indoors or outdoors.
    2013 20x40 Vinyl Ingound Pool. 30K Gallons. Hayward Aqua Rite Chlorine Generator. Hayward C-3030 Cartridge Filter. 1.5 HP Pentair Pump. Pentair Magic Stream II Deck Jets. Pool Automation=Allen-Bradley PLC 5/04. TF-100 Test Kit.
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    Quote Originally Posted by techguy
    We had an electrician do the electric work when it was first hooked up. It has out side GFI breakers installed on the side of the house going to the pool and convenience outlets. The timer will go in between the breaker box and outside GFI breaker box. He did it all to code including the copper bonding wire all the way around the pool which he really felt was a waste but had to be there to meet code. So everything he installed meets code.
    My pump has this information on it.
    Ecco HP 1.5 SPL
    Cat.No EZBN255
    Model S55CXRJD-8050
    RPM 3450
    115V HZ60
    SF Amps 12.0
    The reason I was looking at the TORK timer is that it had a battery backup and digital timer that can be set up to seven different on off settings. I had originally been looking at a TORK that was not digital but had the little pins that go all around for almost unlimited timer settings. Lowes was out of that one when I got there and had only the I mentioned above instead. Not sure I cared about the digital part, but really liked the battery backup part of it. It won't be exposed to the elements being inside.
    Just want to get something installed because it is well over $100 a month right now to run the pump 24/7.
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    Quote Originally Posted by tgreen
    The electrician's bill says he installed a 20 amp 125 Volt twist lock outlet. Doesn't say what size wire used.
