Page 1 of 3 123 LastLast
Results 1 to 20 of 46
Thread: Might remove the Liquidator
    Sep 2007
    Midwest
    330
    I will probably be removing my Liquidator. Can't get adequate flow to maintain my FC. I am back to BBB. Any suggestions as to how I should plug those holes in the PVC? Could I leave the hose clamps and get a plug to screw onto the hose clamp end? Where would I find it? Do they manufacture hose clamps designed to plug these openings?
    Any help is appreciated,
    Dave
    Our pool-
    20x40 Free Form Gunite (3'-8'), 26,000 G, AutoPilot Salt Chlorine Generator SC-48, Aqua blue pebble sheen, Textured Sundek, Pentair Easy touch with remote control, 1hp Sta-Rite Max-E-Pro pump, Max-E- Therm heater 333k BTU, System 3 Mod Media Cartridge filter, and Polaris 380 cleaner with booster pump
    Re: Liquidator removal help
    I would think just get some type of rubber and place over holes and clamp it down. Also if you want to sell your liquidator let me know.
    Pool Details
    21,900 Gal IG Vinyl
    21x40 Mountain Pond
    Filter: Hayward Micro-Clear DE (48 Sq Ft)
    Pump: 1.5 HP Super Pump
    Heater: Hayward NG Heater (H300)
    Cleaner: Polaris 360
    Liquidator & TF100
    Sep 2007
    Midwest
    330
    Bump.
    Anyone else have any other suggestions on how I should plug those holes?
    Dave
    Our pool-
    Tap them, pvc plug wrapped in teflon tape then screwed in?
    Another possibility, although I'm not sure what size hole you drilled, but they make saddle valves where you drill a hole in your pipe, then clamp the valve on the pipe. Possible put one on and close the valve?
    Quote Originally Posted by DLSDO
    Really??? I have mine set at 1.5 and it holds my FC at 3ppm. Did you try and troubleshoot it? I'm sure you did but had to ask.
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    revstriker's Avatar
    Apr 2008
    Texas
    117
    Quote Originally Posted by cruzmisl
    I think this depends on how much sunlight your pool gets, and then of course, if you are using 6% or stronger chlorine (bleach). I know in my pool, which is only 10k gallons, a setting of 2 does not maintain the FC level with 6% bleach. At about 3, my FC level will actually rise a bit, so my ideal setting is somewhere in between (right now my gauge is clogged and not working, so I am just adjusting by feel at this point). My pool also gets direct sunlight (no shade) just about all day long.
    10K White Plaster Pool Built in 2007. Hayward Pump and DE Filter, Hayward Navigator, Liquidator (Removed due to issues), Solar Blanket, BBB user.
    I bought a threaded cap at lowe's in the plumbing section to plug my old chlorinator line which I believe is the same size.
    Just use some teflon tape on the threads
    22,000 IG vinyl liner
    sand filter
    LQ 8 gallon
    Jacuzzi Hot Tub
    420 gallons
    Interesting. My pool is 18'x36 IG vinyl and is in the sun all day long. I use 7% chlorine.
    I did notice a HUGE difference though since I covered the Liquidator in the foil (thanks Sabot). I think that since the chlorine is not exposed to sunlight it retains it's strength. Last year I kept it around 2.
    Sep 2007
    Midwest
    330
    Mikemedic,
    Thanks! Exactly what I need.
    Keith,
    I know. Very disappointing. 26k gallons in direct sunlight with a huge bathing load. The most flow I can get is a "2" on the flow meter....unless I turn off my skimmers....which is not practical. I have one of those pools that chemgeek described...too efficient! My Liquidator is barely above water level, my equipment pad is alittle below water level and the pad is only about 15 feet from the pool.
    With all the valves removed, and the Liquidator open wide, running my pump 24/7, using 6% chlorine, I simply can't maintain an adequate FC level without pouring in additional chlorine into the pool daily.
    I am gonna disconnect my Liquidator and utilize BBB unless anyone has a suggestion that can get my flow rate increased.
    Thanks everyone,
    Dave
    Our pool-
    30,421
    Dave,
    I've got an ugly idea and a graceful one:
    The ugly one is to elevate the LQ...as high as you can get it. The extra gravitational force may be just enough. (of course I don't know if that's feasible with your setup.
    The graceful one is to use 12% chlorine. Do you have a source?
    Mar 2007
    Virginia Beach
    272
    You might also try removing the flow control valve altogether. I would give that a shot as well as 12% Chlorine before abandoning it.
    6000 gal inground fiberglass
    1.5hp pump / sand filter
    Liquidator
    Sep 2007
    Midwest
    330
    Hmmmm. Lots of great suggestions. Maybe I should not be so quick to remove the LQ.
    Where can I find 12%? I get 6% @ Sam's.
    I am gonna try removing the flow control valve also.
    Thanks everyone!!
    Dave
    Our pool-
    Pool store!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    30,421
    I buy 12% from a pressure washing specialty company...they sell about 3000 gallons weekly...pretty fresh!
    Don't raise your tank above the level of your pump. I did this, putting mine up on a milk crate, and it lowered the flow going into the Liquidator enough that it dramatically dropped the rate of flow into the pool (it takes a while for this to happen- 10 or 15 minutes). I put it back on the ground next to the pump, and it worked fine again. Putting it up on a milk crate dropped the flow valve ball from almost 3 to just above 1.
    15,000 gallon AG, cartridge filter, 6 person hot tub
    Sep 2007
    Midwest
    330
    I removed the flow control valve and now my flow is at a solid "3"--- (the center of the black ball is on "3"). So I am running with no valves except the flow meter.
    Next step is to get 12% and see if this holds my FC at an adequate level.
    If I am able to maintain my FC at this setting then I plan to install a 3/4" valve at the base of my LQ so that I can quickly drop the water level for refilling.
    Dave
    Our pool-
    30,421
    Dave,
    If you end up finding 12%, it may well be in 5 gallons jugs which are tough to pour. I built a wooden platform only slighty higher thn the LQ water level right beside it. I then siphon the chlorine in the LQ (pump running). It's pretty painless and would eliminate your need for that 3/4" drain.
    Sep 2007
    Midwest
    330
    Dave,
    I found 12% @ a pool store down the street.
    5G=$2.33/G
    2.5G=$2.76/G
    1G=$2.38/G
    I am interested in your platform and siphon method. Could you post a pic? I still think the drain will be helpful. The problem I encounter is overflow when trying to fill. How do you avoid this with the platform/siphon method?
    Dave
    Our pool-
  20. Back To Top    #20
    revstriker's Avatar
    Apr 2008
    Texas
    117
    I've been playing around with mine for a couple of weeks now and have found that there are a lot of variables in getting the FC right. One setting may work well for awhile, but then we get an extra sunny day and the FC level goes down. I can either bring the FC up manually (which defeats the purpose of the LQ), or adjust the valve so I have a higher flow. The opposite happens on an overcast day. Add to that, your FC level could be different when you have a full 8 gallons of chlorine to when it's half gone or more, and I don't see how you can really manage this thing on one constant setting. I'm just curious how you, or anyone else who has removed the control valve, deals with managing this.
