Results 1 to 16 of 16
Thread: Correct me if I'm wrong please
    Jul 2013
    Lake Charles, Louisiana
    32
    So I've been pool schooling myself this morning and trying to learn, understand & operate Pool Calculator and this is what I've come up with. Please advise me of your thoughts, I'm curious if I'm going the right direction. Thank y'all
    Target Levels & Basic three chemicals needed to maintain your pool
    FC 5.5 Bleach
    CYA 75 Stabilizer/Cyanuric Acid CC 0.3
    pH 7.7 Muriatic Acid
    TA 90
    IG vinyl built 7/1/13, 30,000 to 30,500 gal
    Pentair TA-100D Sand Filter
    Hayward T-Cell-15 Chlorinator
    Pentair Superflow Pump 1.50 hp model # 196239
    Hayward Goldline Pro-Logic
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Correct me if I'm wrong please
    Short version, yes.
    However, the targets are all a range because the parameters interact with each other, and the target values can be different based on pool type, type of chlorination, demographics, etc.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    They look ok to me. You have a SWG correct? Do you have one of our recommended test kits ? How did you come up with CC of 0.3 ?
    Jeff
    Jul 2013
    32
    Yes my pool is has a SWG, and yes I bought the TF-100 test kit with mixer. 0.3 on CC, if above 0.5 is out of range than just figured 0.3 was a happy medium.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Good choice in test kits !
    Jeff
    Smykowski's Avatar
    Sep 2011
    3,065
    So, to be clear, the numbers you posted in your original post are not your pool test results, but just example targets?
    Can you post your latest test results for your pool? Let's get past generalizations and start looking at specifics.
    Jul 2013
    32
    Ill post test results as soon as I get home from work. Just curious to know how useful trichlor could be to me? I work at a chemical plant and have access to trichlor and many other chemicals, solvents, caustic. We make chlorine but its in a liquid / gas form and I'd have no way of transporting it.
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Quote Originally Posted by Scrobbyd
    That all depends on what your current CYA level is. Unfortunately, long term use is going to be limited.
    You are referring to chlorine gas that has been compressed (liquified) and put in metal cylinders, right? I wouldn't mess with that. Is sodium hypochlorite (aka hypochlorite solutions) used or produced? It's pretty safe to transport.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Jul 2013
    32
    FC 11.5
    CC 0
    TA 100
    CH 160
    CYA 30-40
    pH 7.8
    Yes we load chlorine into rail cars and barges.
    Smykowski's Avatar
    Sep 2011
    3,065
    I think those numbers look great. If the water is clear, go swimming.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    For your SWG you want your CYA level to be in the 70-80 range. Is this why you want to use the trichlor, to raise your CYA ? Is your SWG running now ?
    Jeff
    Jul 2013
    32
    No I was only asking about the Trichlor because I have easy access to it. SWG has been running all day but last night I added two gal of acid and 3 lbs of turboshock step 2
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Did you have an algae bloom ?
    Jeff
    Jul 2013
    32
    I did that because this was my test as of yesterday around noon.
    FC 1.5
    CC 0
    TA 130
    CH 160
    CYA Over 20
    pH 8.2
    CL 1
    Br 2
    Salt 3300
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Maybe I'm the only one confused here but....
    • 1. In order to get a pH of 7.8 after a 2 gallon acid addition, your pH would have to of been well over 9 (this is also assuming you only used 14.5% MA)
    • 2. Why the inconsistencies with CYA results? It doesn't appear you added any CYA or stabilized chlorine products. Your spike in FC seems consistent with the addition of 3lbs. of 73% cal-hypo. Can you confirm that's what the Turboshock was?
    • 3. Just a little reminder....the Chlorine/CYA chart has you shooting for a FC of 5 even though you are using dual sources for your chlorine. We're you trying to do just a miniSLAM? You can probably throttle your SWG down until you get back down to your target FC.
    Just like pwrstrk said, you wanna bump your CYA to 70. The FC dip you had is just the SWG unable to keep up. As previously discussed, you can temporarily use trichlor to chlorinate and increase your CYA simultaneously but you should set your SWG to 0% until it's need needed.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I'm just curious if you come back...they would let you take some home? Seems very odd for a chem plant to allow that. I've been in my share of them too.
    Wow.
    Essential Links:
