Results 1 to 9 of 9
Thread: So everything was going good and now...
    So thanks to all the usefull info on here I was able to recover the water from a black/green lagoon to crystal clear pool. Everything was good and then algae started to creep in. i was able to get rid of it following SLAM and now i'm still left with cloudy water. The system has 4 cartridge filters that were replaced earlier this week (not sure if that changes anything). and right before the cloudiness I decided to raise the CYA because it was staying down around 20 so could that have anything to do with it? my readings at the moment are
    FC- 11.5
    CC- 0.5
    TA- 70
    CH- 220
    CYA- 35-40
    ph- 7.5
    Will continuing with SLAM clear the cloudiness? and then is there anyway to prevent it from happening again?
    On a side note... I know it varies pool to pool but how often/much should bleach be getting added? I felt like I was having to add quite a bit everyday for a while to keep the chlorine levels up?
    ~12k gal in-ground plaster, the pressure on the filter stays around 10psi, 1hp pump motor. waterfall, spa that overflows into main pool. hayward cartridge filter still learning the rest. (if you can help msg me lol)
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: So everything was going good and now...
    Your CYA level could have been anything below 20, and it's certainly possible you were losing most of it to sunlight. Do you have a record of your tests you can review? Did you ever let your FC get below your min for your CYA level?
    Yeah i did run out of bleach so i went a day or two with fc dropping at which point i threw in trichlor tab into the autofeed.
    langerking's Avatar
    Jul 2013
    Clermont, Florida (that's near Disney World)
    104
    Forgive me, maybe I am misunderstanding the OP: I am a Newbie too, but in my understanding you can't finish a SLAM with cloudy water. The conditions are: clear water, FC = 0 and pass OCLT
    1) 21,000 gallons
    2) DE
    3) IG (in ground)
    4) Vinyl
    5) Hayward 1.5 hp DE 3600 72 GPM
    Taylor K-2006
    STA-RITE Great White GW9500
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by langerking
    This is correct.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Not quite correct.......FC=0?? I think that should be CC=0.
    langerking's Avatar
    Jul 2013
    104
    Quote Originally Posted by Charlie_R
    Yeah, typo!
    1) 21,000 gallons
    2) DE
    3) IG (in ground)
    4) Vinyl
    Taylor K-2006
    Jeetyet's Avatar
    Jul 2012
    Florida Panhandle
    200
    Just in the interest of precision I believe its CC of 0.5 or lower.
    "The early bird might get the worm, but its the second mouse that gets the cheese." ~ W. Rian Adams
    Relative's IG Vinyl | 16x32 | ~18,600 gals | Hayward 3/4hp Pump | Hayward S244T Filter | Pentair Model 300 Chlorinator (not used) | Polaris 180
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Jeetyet
    ding! ding! ding!
    You're done SLAMing when:
