Thread: Error Code 172 and 186
    Electrical
    What is the recommended voltage on the tri sensor?
    I am getting error codes 172 and 186. My PDA shows check Aqua Pure general fault.
    What is my next step?
    Jun 2011
    Long Beach, CA
    2,778
    Re: Error Code 172 and 186
    Those are codes relating to the sensor. Do you have enough flow through the cell? You will want to make sure your filter is clean along with the cell and sensor. If all seems well with those items then make sure the sensor cable is fully plugged in to the electrical board. If that is fine then your sensor might need to be replaced. Do you have the newer 3 port cell or the old 2 port cell and how old is the system?
    Jun 2011
    Long Beach, CA
    2,778
    Re: Electrical
    The mods need to combine this with your other post. I believe the voltage should be 22-28 volts.
