Thread: Pentair Heater: Sta Rite SR400NA
    Pentair Heater: Sta Rite SR400NA water leaking out of blower. Is there water in the gas tank? Does this mean water is leaking out of heating coils?
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    Re: Pentair Heater: Sta Rite SR400NA
    Does the heater keep running?
    To see if there is water inside the canister, take out one of the lower bolts on the header, where the water goes in and out. If water comes out, the heat exchanger has been compromised and the unit should be replaced.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Thank you for confirming my suspicion.
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    Quote Originally Posted by dyryan
    Did you remove one of the bolts and find water coming out?
    Paul
