Results 1 to 7 of 7
Thread: JANDY Aqualink PDA Programming problem
    May 2013
    New Orleans, Louisiana
    14
    So, I was having problems with my pool equipment, and this technician took out my old jandy aqualink control board and installed a new one that he said was covered under warranty. But when I try to use it with my old PDA, the PDA controls all the functions except it doesn't have a control for programming. So now I can't program the pump and cleaner to run at certain hours with my PDA. I can only turn things on and off. He claims it is the replacement to my old one which he says went bad. Not true, but that's another long story.
    Now he's offering me a iaqualink jbox and antenna and telling me I can just install that and just use my phone. I'm a little concerned about him making more of a mess of things. I can't figure out why my PDA is compatible and works with everything except for programming.
    15k, IG, gunnite, Pentair whisperflo, Pentair Clean & Clear Plus ccp520 Cartridge, Polaris valve actuator, Goldline valve actuator GVA 24,Aquarite Goldline electronic cell, remote control upgraded from Polaris Sol 1000 to a Jandy PDA Aqualink RS, spa attached with spillover, Built in 3/2004.
    Mike_W's Avatar
    Aug 2011
    Orange County, California
    142
    Re: JANDY Aqualink PDA Programming problem
    After my upgrade to an iaqualink system, my PDA behaves exactly as you describe. To program anything I need to use the iPad or computer interface. Since the PB says that he can just add the iaqualink jbox and antenna to give you full iaqualink functionality, it sounds like he installed an iaqualink compatable control board. If you don't want to go the iaqualink route, I'd suggest you get the software version of the board and give Zodiac/Jandy a call to see if it can be configured for "normal" PDA operation via a jumper or a dip switch.
    Mike
    ~17' x 34' IG pool with attached spa - 20500 gallons - Gunite with a "pebblesheen"-ish finish
    Jandy iAqualink with iPad and Jandy PDA remote - Pentair IntelliFlo VS 11018 Pump
    AquaRite SWCG - Pentair SMBW 4060 DE Filter - Really Old Raypak heater
    "Wall-E" an Arneson-Hayward Navigator - A couple of Jandy/Zodiac WaterColors LED Lights - Blue-White F-1000 Flow meter
    I just bought and installed an IQ900-RS iAQUALINK UPGRADE KIT FOR RS SYSTEMS.
    All terminal strips easily matched to the new board. The only exception was that the intake moved from the top to the bottom of the board.
    I am looking for a diagram for this new board to make sure I have the dip switches set correctly and wireless in the correct location.
    Can't seem to find any picture diagram of this board with added dip switches. Any help would be appreciated.
    Mike_W's Avatar
    Aug 2011
    142
    Chris,
    My old Jandy PDA system had one dip switch bank with 8 switches. The iAqualink has those switches plus another bank, with 4 switches, located below it. If those are the switches you are referring to, see if this document helps. Look on page 42.
    Mike
    Link http://www.zodiacpoolsystems.com/~/m...1071/6919.ashx
    Mike_W,
    Thanks for the quick information and reply. This appears to be the board. I will set the dip switches according to this manual and turn it on.
    I'll post back later with the results. Thanks again
    Mike_W's Avatar
    Aug 2011
    142
    You are welcome - Glad I could help.
    Mike
    May 2013
    14
    Thanks for the advice. I ended up just using my old PDA. But I still cannot get it to schedule cleaning, pumps, etc. It can only turn things on or off.
    the guy who put it in for me somehow programmed it to run certain things regularly. But I can't reach him to find out how he did that. He used something other then the pda to do it. I don't know if he has some computer that communicates to the program or what. I'd like to just do that instead of getting the iaqualink phone thing.
