Results 1 to 16 of 16
Thread: New vinyl pool build in southwest Louisiana
    Jun 2013
    Southwest Louisiana
    72
    We are in the process of having our pool installed. It's been a very slow, long process but are slowly nearing the end. Just waiting on the liner to come in now. It's a custom vinyl pool. We added a bench in the deep end and have wide steps across part of the shallow end. It's a lagoon shape that we went with.
    Installed in September, 2013 18x36 (28,000 gallons) lagoon shaped, vinyl pool, with steel walls. Pentair intelliflo variable speed pump, intellichlor salt generator, pentair cartridge filter CCP320
    Jun 2013
    Southwest Louisiana
    72
    Re: New vinyl pool build in southwest Louisiana
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Welcome neighbour looks like things are shaping up, who did you use for your pool build?
    Jun 2013
    Southwest Louisiana
    72
    We went with crystal creek pools out of Jennings. They were the only company I found that would do a custom liner pool.
    Jun 2013
    Southwest Louisiana
    72
    They came and sanded the cement today. Now just waiting on the liner to come in and have it installed. We can't wait to see the end result.
    Apr 2013
    Delaware County, PA
    1
    WOW!! That looks super! Do you mind posting what it cost? I am just starting to get quotes and due to the cost of an IG gunite or a fiberglass pools being so high, I am thinking of going with IG vinyl. I love the custom look and size of your pool. If you have completed pics to post, I'd like to see them.
    Thanks
    NEWBIE
    Jun 2013
    Southwest Louisiana
    72
    This cost us $32,000, the pool was originally $30,000. We upgraded the pump, added the seat in the deep and added 4 deck jets. It will also have two led lights. The liner is scheduled to be delivered sometime on Monday and he will install it on Tuesday. I'll be sure to post photos once its finished.
    Jun 2013
    Southwest Louisiana
    72
    Ok I may have a problem! We live on 40 acres and the land slowly slopes down from the front of the property to the back. We live in the back. My pool builder came and dug while we were out of own for softball for my daughter. I told him the land sloped and that we figured the pool would need to be built up. He said he would shoot grades. When we came home the hole was there and I asked if it was high enough out the ground and he said yes it's perfect for our yard. Well we just had a hard fast downpour and the water ran over the cement deck and Ito the pool. Is there anything I can do to fix this? We still don't have the liner in yet so it's not finished.
    30,431
    OMG. That is really a huge issue. Rainwater allowed to flow in to a pool is a NEVER ENDING source of agony.
    I would say a fix is absolutely mandatory.
    Several ways to keep the water out of the pool by cutting a path or a drain that keeps it below the lowest deck level but it simply has to be done.
    My first reaction is PB might not be up to speed on correct drainage so he may need help, but I would go no further until that was resolved.
    Jun 2013
    Southwest Louisiana
    72
    Going to show him the photos tomorrow and see how he plans to fix it.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Now I REALLY want to know who the pool builder is so I know who to tell people to be cautious about
    Jun 2013
    Southwest Louisiana
    72
    I spoke with him this morning and he said it would be an easy fix, that he will come take care of it and make the water drain away from the pool. I'm so glad we found this out before the liner went in. That should happen tomorrow!
    Ukie's Avatar
    May 2012
    Export, PA
    83
    Quote Originally Posted by Isaac-1
    I believe nothing is wrong with PB in this case. Site just need some grading to fix the issue.
    -- or --
    we can go to "He said he would shoot grades" and ask what he was thinking about.
    ktyler, what stone did you use for coping? Is it travertine?
    Lagoon shape, 23,600 Gal, steel walls by International Swimming Pools, "ultra-seam" liner by Latham, Pentair 011018 IntelliFlo 3HP Variable Speed Pump, PentAir CCP420 filter, Heat Siphon Z575HP, PentAir IC40 SWG, 2 LED Lights (Pentair Intellibrite 5G, 110V). 4 x 1.5’’return lines, 2 x 2’’skimmer lines, 1.5’’ waterfall line. All plumbing is "TigerFlex" pipe, all lines plumbed individually. Deck: travertine glued over concrete.
    Jun 2013
    Southwest Louisiana
    72
    He came and checked it out this morning and said it would be easy to grade it so the water went away from the pool. He is going to do that tomorrow, the ground was still too wet today. I'm glad it rained like it did before he liner was in and it was finished. Now he can fix it and hopefully we will be fine. He told me he could have built it up, he just didn't want it to be too big of a drop off near my house and was confident that after he graded it we would be fine. And yes it's travertine that we have for the coping. So far this has been the only issue we have had, all of his work seems to be great, although a little slower than what he told us it would be originally, but from talking with friends that have used other builders, it seems everyone has that complaint. I'm just glad we are nearing the end now.
    Ukie's Avatar
    May 2012
    Export, PA
    83
    Quote Originally Posted by ktyler
    I believe that's how pool construction usually goes due to weather related delays. We are scheduled for similar lagoon-style pool for mid September.
    What size is your coping paver? 12''x12''?
    Jun 2013
    Southwest Louisiana
    72
    Yes they are 12x12 pavers. Then we have 4 ft of concrete around the back side and poured extra for an area for lounge chairs. We also put umbrella holes around so when the kids are in we can have umbrellas up to offer shade.
