Results 1 to 9 of 9
Thread: Help! Short term circulation fix
    SJS101's Avatar
    Apr 2013
    Louisiana
    14
    My little girl is turning 4 and we have a big swim party planned for family/friends Sunday 8/25/13. Last night my pump motor stopped running and was red hot to touch.
    I ordered a replacement pump motor but it may not be here until Monday!
    Water is beautiful now but I don't want it mucking up before the party. I would like to superchlorinate the pool to head off any potential issues as it will be sunny all weekend.
    What is the best way to manually circulate bleach if my pump is not running. Please help save my little girl's party.
    Current test results:
    CYA 30
    FC 4
    18 X 36, 29 K gallon, Sand Filter, Inground Vinyl Lined, 3/4 HP pump
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    Re: Help! Short term circulation fix
    Get in the pool and walk around in circles where you can touch. For the deep end? Hummmm walk around the edge and use a broom? to move the water? Go on Craigslist and ask for the loan of a pump even if it is a small one? OR maybe someone has one to sell cheap?
    Good luck!
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    My friend had a similar issue and he borrowed my sump pump. Worked perfectly.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    If there's a Harbor Freight in your area, you can buy a submersible sump pump for very cheap. Do a search in Google for "Harbor Freight 20% coupon", print it out and get it even cheaper. You can use the pump next season if you ever have to raise your PH by aeration by setting the pump on a pool step and putting some PVC fittings on the pump output to throw the water back into the pool with a splash. That's a $35 solution to your problem.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    SJS101's Avatar
    Apr 2013
    Louisiana
    14
    Looks like the sump pump is the way to go. Thanks for the advice.
    Jul 2011
    844
    Great if you ever have to drain too.
    Bestway SWG
    SJS101's Avatar
    Apr 2013
    Louisiana
    14
    Well FedEx showed up with my replacement motor at 930 this morning. So need for a sump pump at all. Got it taken apart and mounted the new one and we're at full strength.
    However, I did give my family a good laugh spinning in circles last night circulating 2 gallons of bleach manually "Swan Lake" style!!
    Jeetyet's Avatar
    Jul 2012
    Florida Panhandle
    200
    Quote Originally Posted by SJS101
    ...However, I did give my family a good laugh spinning in circles last night circulating 2 gallons of bleach manually "Swan Lake" style!!
    Got pics?
    "The early bird might get the worm, but its the second mouse that gets the cheese." ~ W. Rian Adams
    Relative's IG Vinyl | 16x32 | ~18,600 gals | Hayward 3/4hp Pump | Hayward S244T Filter | Pentair Model 300 Chlorinator (not used) | Polaris 180
    SJS101's Avatar
    Apr 2013
    Louisiana
    14
    I made sure there was no recording devices in sight. So, no footage unless one of the Government drones was running surveillance on me
