Results 1 to 15 of 15
Thread: Pool Bottom
    Jul 2010
    Longwood, FL
    151
    Pool Bottom
    When I clean my pool deck with pressure wash small debri/dirt fell on pool bottom.
    I tried vaccum / brush but it wont come off !! It is stuck on the bottom
    Is there special brush for this ?
    15,000 Plaster IG Pool
    AquaRite SWG, C1750 Catridge filter
    G3 Vaccum, T-100 Kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pool Bottom
    Stuck? Are you sure there are particles stuck there, and not particles that stained?
    Essential Links:
    Jul 2010
    Longwood, FL
    151
    Re: Pool Bottom
    Quote Originally Posted by Brushpup
    If I go down & do it with hand they come off. So I think they need pressure.
    Re: Pool Bottom
    Dirt and debris usually vacuums and brushes up easily.
    It sounds more like staining or algae. Is there any green tinge when you scrub them by hand? Is morning CC > 0.5 or overnight FC loss > 1.0?
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    Jul 2010
    Longwood, FL
    151
    Re: Pool Bottom
    Could be staining I suspect , what can I do to fix it
    Re: Pool Bottom
    First step is to figure out if it is an organic stain or a metal stain. Try holding a puck directly on one of the spots and see if it fades or removes it. If so, it is organic, and can be cleaned by raising the chlorine level and a lot of brushing.
    If not, it's likely metal. Start here: pool-school/metal%20stains
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pool Bottom
    Well then what do you mean they will come of "by hand"? Using a brush, a tool, your fingernail? I thought we were talking about debris here.
    Essential Links:
    Jul 2010
    Longwood, FL
    151
    Re: Pool Bottom
    Sorry for the late reply, I was out of town. I have bird droppings @ bottom of my pool. They are in 8 ft & wont come off with pool brush or pool vac !!
    Any tips!!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pool Bottom
    Bird droppings are not going to stick. Sounds like staining.
    Essential Links:
    Jul 2010
    Longwood, FL
    151
    Re: Pool Bottom
    Ok any solution for Staining ?
    Thanks
    30,427
    Re: Pool Bottom
    There are several articles in Pool School that will get you started learning how to deals with stains. I would suggest to read "The ABC's of Pool Water Chemistry" to get started and then go from there.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pool Bottom
    Also, could you post a pic or two of the spots?
    Jul 2010
    Longwood, FL
    151
    Re: Pool Bottom
    Sure let me do that . Thanks I will get the pictures today.
    Jul 2010
    Longwood, FL
    151
    Re: Pool Bottom
    Pictures of my pool
    One is 8Ft floor with black dots
    second one is 4ft clean floor
    Thanks
    Note: I used FastStone photo resizer (Free) you can reduce your file size by 90% without loosing anything.
    Jul 2010
    Longwood, FL
    151
    Re: Pool Bottom
    Sorry I posted pictures on wrong thread.
    pool-stains-t70305.html
    Mod Edit: I moved them to your thread here (just above this post). Moderator linen
