Results 1 to 14 of 14
Thread: "Other" uses for Trichlor Tabs now that i've switched?
    Aug 2013
    Hammond, LA
    19
    I have a bucket full of 3" Super HTH trichlor tabs left over.
    Also have some of those Arm & Hammer Clear Balance tabs. Not sure what I could use those for.
    But I had a couple ideas for the chlorine tabs.
    Place a tablet at the end of the discharge line on my home septic system.
    If my CYA gets too low, actually use them in the pool for a limited time?
    Any thoughts?
    No More Pool!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: "Other" uses for Trichlor Tabs now that i've switched?
    You'll need them eventually. You will lose some CYA with splashout, backwashing, or when the pool needs emptying after a big storm, and they're an easy way to replenish it and buy yourself a few days off the jugdumping at the same time. They're also great for vacations.
    Aug 2013
    Hammond, LA
    19
    OK, good to know i didn't waste those $$.
    The arm & hammer tablets are mostly Baking Soda along with a "Clarifier".
    Haven't determined what that actually is yet, no luck googling.
    Might write the company and ask for an MSDS.
    No More Pool!
    Aug 2013
    Hammond, LA
    19
    Can find it here: https://wercs.churchdwight.com/webviewer.external/
    85-95% Sodium Bicarbonate
    5-15% Sodium Carbonate
    So I can put a tablet on a small plate in the fridge for odors!
    No More Pool!
    Jun 2011
    Long Beach, CA
    2,790
    Here is a link that has a discussion about the A&H tabs, arman-hammer-baking-soda-tablets-any-downside-t14697.html.
    Aug 2013
    Hammond, LA
    19
    Thanks ping, I had seen that one. Need to determine how much TA 1 tablet actually adds.
    No More Pool!
    tcat's Avatar
    May 2012
    Austin, TX
    731
    How about in a commode tank? Aren't they the same stuff as those bleach disks?
    I have half a bucket too. Put 4-5 in my chlorinator for a week if my CYA goes below 40.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    nedchavez's Avatar
    Jun 2012
    Grand Rapids, Michigan
    111
    Do not put them into your home septic system. You have beneficial bacteria in that system that is needed to digest waste. You do not want to kill this bacteria!
    Also, in a commode tank, it will make the plastic tank components very brittle and subject to very premature failure.
    16' x 32' IG vinyl liner w/ hopper bottom (12,500 gal), Single-speed 1 HP Sta-Rite pump, and 300# Cristal-Flo sand filter, TF-100 test kit
    tcat's Avatar
    May 2012
    Austin, TX
    731
    I have a "Neverscrub" gizmo in my tank(s) which uses expensive refills. I bought a quart of 1" tabs and use them. I was thinking breaking up the 3" tabs would also work. You fill a small plastic container and the bleach never hits the other components in the tank. Seems to keep hard water stains away.
    DIY chlorine feed
    BBB
    Apr 2010
    Buckeye, AZ 85326
    619
    I've heard of them being used to keep pigeons from roosting in your eaves or anywhere you have the little flying rats trying to hang out.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by tcat
    Trichlor is very acidic so will rust the components in the tank so do not put them there. As shown in this MSDS, the pucks from Clorox are not Trichlor and have high pH. This link from Clorox says that the tablets are dichloroethylmethyl hydantoin which is very similar to bromine tabs but using chlorine instead. Though these are acidic, they are not as acidic as Trichlor and the tablets also have sodium citrate and sodium carbonate to balance out the pH to make them alkaline, most likely to prevent metal corrosion since the pH would otherwise drop when the chlorine is used/consumed.
    Aug 2013
    Hammond, LA
    19
    Re:
    Quote Originally Posted by nedchavez
    Right, I meant at the end of the field bed line where it discharges into the ditch.
    No More Pool!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Just save them until you can use them to top off CYA or for vacations. As long as they stay dry they will last for years. Just don't store them next to anything metal. They do off-gas and will cause rust over time.
    Love TFP? Become a
    TFP Supporter!
    thepiratemorgan's Avatar
    Aug 2010
    Central NY
    185
    Quote Originally Posted by beameup
    Any thoughts?
    What I do is let my CYA drift down after the spring rains and then when I go on vacation in July I use the "pucks" to chlorinate and increase CYA during the week. Last two seasons CYA starts at 50, drifts to 40, and 3 pucks during the week vacation and back to 50 I go!
    14,600g / 24ft. Round Above Ground with Solar Cover
    18" Hayward Pro Sand Filter
    1 HP Hayward Powerflo Matrix Pump running 10am - 8pm
    Full Sun (when we get sun ... LOL): Approx. 10am to 7pm
    Using the Trouble Free Method, and loving it!! Arrrrrrrr!!!!
