Results 1 to 12 of 12
Thread: Problematic first season with pool - time to go to BBB?
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    95
    FC 1
    CC 0
    TA 110
    Ph 7
    CYA 90!!!
    My first season owning a pool. I have a nature2. I thought all was well, although I've had mustard algae and cloudiness fro time to time. But now all seems ok - but CYA is at 90.
    I know that high CYA is making my chlorine ineffective. I also guess that the trichlor pucks in the nature2 are driving it up.
    So I am thinking of making a clean break of it all and going BBB. (I've read pool school and I understand pool chemistry ok).
    So what would you recommend as my steps to fix the cya and get control of this situation.
    Many thanks - this is a awesome resource which I wished I'd found before I built the pool!!!
    18k vinyl IGP, Sand Filter, EasyTouch Control Sys, Pentair Intelliflo, Intellichlor IC 40 SWG, Rheem Heat Pump.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Problematic first season with pool - time to go to BBB?
    Welcome to the forum!
    1. Buy a good test kit if you haven't already.
    2. Ditch the nature2.
    3. Do a 50% drain/refill to get your CYA to a manageable level.
    4. Adjust pH to 7.2-7.5
    5. SLAM it.
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    95
    Quote Originally Posted by Smykowski
    5. SLAM it.
    Thanks for the quick response!!!
    1. I have a Taylor K1005. But I guess I should get the better one. - I'll do that.
    2. To ditch it - just remove the cartridge - but leave the unit there?
    3. Any danger with draining? Its a vinyl pool - we have heavy clay soil and the water table is fairly low - when the pool was dug the weater only ever filled about 6 inches in the bottom.
    4. Will do.
    5. OK.
    Other question - I am guessing I need to ditch the trichlor pucks also and go bleach.
    Also - after SLAMing - then I just maintain using BBB and I am good to go?
    Is it really that easy?
    many thanks!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    Pretty much what Smykowski just posted...So if you were looking for consistency in recommendations, I think you have it!
    Quote Originally Posted by gatorbrit
    Yep...You've got that right! Time to ditch the pucks/nature2
    If you have read Pool School, you know the importance of having a good test kit. If you don't already have one, here is a comparison of the Recommended Test Kits.
    You are looking at a 50% water replacement (partial drain & refill). This is the only way to lower CYA.
    After doing the 50% drain & refill, you will need to run a full series of tests. In all likelihood, you will need to SLAM your pool.
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    95
    Thanks for your comments. Will be draining this weekend.
    Is the Taylor K1005 OK - or should I invest in the better version?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, gatorbrit
    Make sure you read this pool school article on test kits: http://www.troublefreepool.com/pool-...kit_comparison The K1005 is not one of our recommended kits. Many of us have the tf-100 since it is the best value.
    Donldson's Avatar
    NW Ohio
    2,917
    You at least need to add an FAS-DPD test to your kit, you can order it from the Test Kits link in my signature. It allows you to accurately measure up to 50 ppm FC with an accuracy down to 0.2 ppm.
    Once everything is in range and you finish SLAMing it really is that easy. You have a chlorine pool, you are just adjusting how you maintain it.
    Also, tear out the Nature2 unit (or at least the mineral cartridge), it introduces copper in to your water. Copper helps kill algae but causes staining and green hair. Proper chlorine levels make it entirely unnecessary.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Do you have a high water table ? Just something to keep in mind for the partial drain refill.
    Jeff
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    95
    I don't think that the water table is too high. When the pool was dug, the hole only had a small amount of water in the bottom.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    The ground water level can and does change depending on how much rain you have been getting. Always keep a least a foot of depth in the shallow end to keep the liner from floating/shifting.
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    95
    Quote Originally Posted by linen
    The pool is 3' to 7' so the average depth is about 5'. So I'll draw it down about 2' and the refill. That should be close to 50% of the water. I can always drain a bit more later on if I am still a bit high.
    Thanks - and I became a supporter - this help alone was worth the donation!
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    95
    Update:
    After SLAM and draining :
    Cya- 25-30. Bit low?
    Ph 7.5
    FC 4.25
    CC 0
    Ta 90
    Ch 150
    I think all is well, although my CYA might be a bit low. But after dealing with draining I will give it a day or two before I adjust.
