Thread: accurate thermometer??
    What/where can I buy an accurate spa thermometer?? Like + or minus 1 degree? I have two thermometers and one says 104 and 1 says 108 degrees. Any help would be appreciated. Thanks.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: accurate thermometer??
    It's like the man with two watches. A man with only one always knows what time it is.
    I would suggest a lab supply if you really want accuracy. They will have a variety of types and at least a few that can stand being banged around in a spa. Good luck, and welcome to TFP.
    Essential Links:
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    I did some internet searches out of curiosity and did not find a particular brand or type that stood out head & shoulders above all others as the gold standard. You may want to browse through this thread on a digital thermometer that several members had purchased: http://www.troublefreepool.com/pool-...or-t19328.html. Considering this thread was posted in 2010, the identical unit may or may not be available or it might have been replaced with an updated unit.
    I would first narrow it down to which type of thermometer your interested in (digital, dial-type, or the traditional tube-type). I would get one that is easy to read.
    A couple of outside-the-box suggestions to consider...You could look into an aquarium water temp thermometer, an NSF (National Sanitation Foundation) food service thermometer, or a laboratory thermometer. Of these three, you will probably get the best bang for the buck with the food-service thermometer. This is often a dial-type unit that is easy to read where you dip the probe end into the water and then get a reading within a few seconds. However, I wouldn't leave it in the spa as many of these units are not entirely water-tight. With any of these units, just make sure the working temperature range covers the expected temperature range for your spa.
