Results 1 to 14 of 14
Thread: Trying out my new chlorine floater
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    27000 gal 18x36 rectangle In-Ground built in 1978
    Vinyl liner, 3/4hp Hayward Super pump, single speed 3450rpm
    SWG: Hayward Aquarite AQR15
    Sand Filter: 300 pound sta-rite T-240BP-1, 3.14 sqft surface area
    K-2006 Test kit
    38,408
    Re: Trying out my new chlorine floater
    Did you put pin holes in it?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,640
    Some explanation would be nice.
    Is this a joke? It's not a good idea.
    Support the site
    May 2013
    North East Ohio
    959
    that liner sure is wrinkled
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    I got the idea from another post on here somewhere where they said they dropped the bottle, and it landed on it's side or something, then later it came floating to the top... been a while, don't remember the exact details.
    The cap is off, poured out a little to get some air in it, but since the chlorine is heavier than water, you can just watch it slowly coming out of the bottom (you can see the blurry trail in the top pic). Eventually, it'll just be water inside the bottle.
    As far as the liner,, yes, it's just below the first drop below the shallow end where people are walking up over the ledge from the deep end, and it's scooted down the hill a bit in the middle
    K-2006 Test kit
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I guess it may work but knowing I can pour it in front of a return in 30 seconds and be done, I don't see the need.
    -- Guy --
    Mar 2007
    San Rafael, CA USA
    12,082
    I suspect it will empty out too quickly with the opening as big as an open bottle top (inverted so that it's open at the bottom). Others have done this technique but with a smaller hole opening. Unfortunately, bottle shapes aren't designed to keep the orientation in one direction, but a flanged shape with air on top could work as could something with a low density (e.g. foam) top.
    I believe the use for this would be more for vacations when one is not around to dose with chlorine, though for up to a week the use of Trichlor pucks wouldn't be a problem unless one's CYA was already too high.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Essential Links:
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    So it take about 30 minutes to drain a 121oz of 8.25% bleach with the cap off.
    Won't work for long periods of time, but might get weird looks from the wife if you put a bunch in at once.
    K-2006 Test kit
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I took a gallon of 12% last night, poured half of into a measuring pitcher and poured into my pool last night (in front of the running return). It took all of 30 seconds.
    Guess what? I will do about the same thing tonight and every night of my swim season with a different amount each time (based on my testing and FC levels).
    -- Guy --
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I LOL'd.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    I've been SLAMing for a week, just having some fun with it.
    Geez, you'd think on a board of recreation loving people you guys would be more fun. Some of you really need to stop smoking the dpd powder, break out the wine and chill a bit.
    K-2006 Test kit
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    And I LOL'd again, thanks for the funny...
    18'x43' Sport Pool
