Results 1 to 1 of 1
Thread: Pool Screen Enclosure Question
    We have a full screen enclosure to cover the pool and deck (keeps the critters out!). The cage has three beam that supoort the roof panels. These beams are perpendicular to the back eave of the house. They attach there to the "super" gutter that runs along the eave.
    The problem I'm having is that at the attachment point there is substantial leaking. I'm not sure if it's coming from the gutter or is draining out the end of the beam. Either way its problematic as it is staining the paver surface of the pool deck below each attachment point.
    Is the water supposed to drain out of the beams like that?
    [attachment=0:2fd80pyz]Beam.jpg[/attachment:2fd80pyz]
