Results 1 to 11 of 11
Thread: Connecting Pool Plumbing
    Jun 2010
    Toronto, Canada
    34
    Yesterday I replaced the plumbing line that connects my pump and filter. However, when I turned on the pump today, there is water leaking at both ends. I've used steel clamps to secure the tiger flex line, but no I'm wondering if I should also be using primer and pvc cement or should the clamps be positioned differently?
    Here is a picture of the tiger flex pipe and the connector before they are secured.
    Here is pictures of the the two pieces after they are secured by steel clamps on both ends (you can see water dripping in the 2nd pic):
    I should add that the blue pvc cement seen in the pics was used to connect the two plastic pieces (white and grey in first pic) that I'm attaching the flex pipe to. The pool store actually did this for me.
    Thank you
    20,000 Gallons Inground Vinyl Pool, 1 skimmer, 1 floor drain, 4 return jets, 1 vacuum intake
    Hayward Vari-Flo XL sand filter (SM2506T), Hayward EZ Flow Pump (SP-3107X10), Emerson Pump Motor (EB228), Hayward Comfortzone NG Heater, Hayward Chlorinator (CL220)
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Connecting Pool Plumbing
    See bullet one... that is supposed to be glued into a PVC connector.
    From Tiger Flex website
    Tigerflex Spa Hose
    PVC pool and spa hose is specially designed for use in the installation of tubs, spas, swimming pools, filters and similar water transfer applications. Solid cream color. Service temperature range -4F to 150F.
    Note: Like other materials, Spa hoses can be damaged by rodents or insects including termites. Warranty does not cover these damages. Spa hose should not be used underground in areas infested by termites.
    Features and Benefits of Tigerflex Spa Hose:
    Designed to be glued into Schedule 40 PVC fittings
    Replaces rigid pipe for plumbing pool, spa or hot tub installations
    Very flexible - ideal for working in confined areas
    Cost saving - requires fewer fittings than rigid pipe when plumbing a normal spa or hot tub installation
    Smooth bore construction allows unresricted flow
    General Applications:
    -- Guy --
    38,284
    Yeah, I am not sure it is meant to be installed on a barbed fitting like that ... it "should" work if the fitting was a nice tight fit and aggressive barbs to dig in ... maybe the barbs are too small?
    Or you could cement it into a fitting as it is designed for ... although if you intend to take it apart, you will need unions or something.
    Apr 2013
    Battle Creek, MI
    298
    Dump the PVC adapters they glued the hose barbs into, replace them with the same identical PVC fitting and glue the flex hose right into them. Or adapt a union to the female pump threads that will accept the flex PVC hose.
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    Jun 2010
    Toronto, Canada
    34
    Thanks, guys.
    So it sounds like there was no need for the grey PVC part (one with barbed fitting) to be glued to the white PVC part . Instead, the tiger flex hose should have been glued directly to the white PVC part. Does this sound correct?
    Also, I guess this means if there is a leak in the future, I'm replacing the hose and both white PVC parts that are attached at each end since they are glued? I believe the pool store was trying to come up with a solution that would make it easier/more cost effective to fix future leaks.
    38,284
    You can add unions glued almost directly to the fitting screwed into the valve (with a short piece of PVC pipe) and then glue the hose into the other half of the union. That way you can open the union when you need to open the top of the filter or have a leak to deal with.
    Apr 2013
    Battle Creek, MI
    298
    Quote Originally Posted by cipher
    So they sold you a leaky fitting that would make it easier to fix the leak? Glue it up right the first time with a union, or even better a union with a shutoff, and be done with it.
    Jun 2010
    Toronto, Canada
    34
    This makes sense now. I'll either glue it directly or glue it with unions to give me more options in case there is a leak in the future.
    Now the embarrassing part. When I turned the pump off the other day, after I had noticed the leak, it had probably been running for 2-3 hours. However, yesterday when I looked in the pool I saw sand on my steps and in the deep end. I then realized I had reversed the connections between the pump-filter and filter-heater. The pump was run to the "Return" outlet on the filter and the heater was run to the "Pump" outlet on the filter!
    At this point, I have two questions:
    1) Did I damage the filter (laterals etc)
    2) If it's not damaged, can I just vacuum the sand back into the filter once I reconnect the lines
    X-PertPool's Avatar
    Exeter, PA
    1,385
    I've used barbed fittings on tigerflex in the past, you need to use a liquid teflon on the barbed fitting when you go to insert it into the tigerflex. With that being said, I've still seen it leak. Just glue to the pipe and you'll be fine (no barbed fittings)
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Aug 2009
    SW Wisconsin
    518
    same here. I've tried the flex line on barbed fittings..and they simply will leak pretty much no matter what. If not now..in time they all do. That flex line is meant to be glued into a PVC slip fitting, not onto a barb.
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    22,548
    You probably didn't hurt the filter by running it backwards a little while since you weren't clearing algae. Just vac the sand up and it should be fine.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
