Thread: Pool water clear but algae on sides
    Just got back from vacation. the pool walls had some algae on them but the water is clean. i have a basic test kit and here are my numbers,.
    tc 3
    fc 3
    cya 80
    ph 7.5
    alkilinity 70
    ch 110
    salt 3400
    31000 gallon pool 18 by 36 with 4 foot roman ends on each side. mod media filter, swg, no water falls or deck jets vynyl liner..
    why would i be getting algae on the sides.??
    38,524
    Re: Pool water clear but algae on sides
    Welcome to TFP!!!
    Quote Originally Posted by SALTPOOL
    Easy, because your FC got too low.
    According to Pool School in This Chart, the MINIMUM the FC should be with a SWG and a CYA at 80ppm, is a FC of 4ppm.
    You need to SLAM the pool. [slam:1rk72ybh][/slam:1rk72ybh]
    This is done with the SWG off and you WILL need one of the Recommended Test Kits.
