Thread: White stains on pool
    Aug 2013
    Mcallen, TX
    39
    Hello, just had my pool completed about 2 months ago and i've been noticing these white stains on there. In the beginning there was a lot of dirt in pool as a result of high wind and i'm thinking it may have contributed to it. I didn't think much of it until a friend who also owns a pool with blue quartz brought it up.
    At first i was thinking it was algae, but my OCLT is only .5. I have never done the slam method on my pool since it open as a result of the water being very clear, and it being pretty much in check the whole time ( chemical wise). Anyone have an idea what it is and how i can get rid of it?
    FC 3
    cc 0
    cya 60
    TA 120
    ph 7.4
    17k gallon pool, pentair whisperflo pump 1hp, Pentair FNS Plus 36, SWG Hayward Turbo Cell 15 40,000g, blue quartz with pebble finish landings/bench, ultra pure water cleaner.
    Feb 2008
    Denton, TX
    5,061
    Re: White stains on pool
    It's hard for me to tell whether I am seeing it or not. Have you spoken to your installer about it?
    I would like to recommend to you, the purchase of a better test kit. You left out calcium hardness in the results and calcium is a notorious culprit in plaster not looking like it should. Consider going to tftestkits.net an get yourself a TF-100 kit.
    Aug 2013
    Mcallen, TX
    39
    I just didn't check It. I'll check for calcium later. I had checked it a while ago and it was fine. I'll check it again
    Thanks for response!
    Aug 2013
    Mcallen, TX
    39
    I checked the calcium hardness and it was at 330 ppm. Seems to be right on according to pool book. Here is another pic.
