Results 1 to 17 of 17
Thread: New Vinyl Pool in the Buckeye state!
    Jul 2012
    Ohio
    19
    So we finally started our pool project . Our PB is about 3-4 weeks behind because of the rain and weather here in Ohio this summer. I thought we would be swimming by the first week in August, but it wasn't meant to be. I did my research and talked to 4 different builders and ended up going with the best! I personally know a couple people he has installed and I also volunteer at a summer camp where he built the pool.
    To prep I removed 15 large Maple. Oak and the biggest sassafras tree I have ever seen. I also cut down and HAND SPLIT all of the wood myself, about 10 cords so far. The trees were over hanging the area for the pool and were just mostly unsightly. I have plans to do some landscaping up there and needed room for my hog pit (for all the pool parties coming up ). I had the company doing the excavation come out a day early and pull all the stumps for me. As they dug the pool I had them leave the dirt on the hill where the stumps were so that I can rent a bobcat and grade/level the area later.
    Pool Details:
    Fort Wayne Elite Polymer
    Grecian 18'6" X 36'6"
    Vinyl Liner
    Deep End - Diving Board
    Hayward 1HP Super Pump
    Hayward Cartrige Filter
    2 Returns
    One Skimmer
    8' Steps
    Hayward Color Logic LED light
    Layout
    The Big Dig (you can see the area where the stumps were and now the dirt is!)
    More pics to follow!
    21K gallon 18'6" x 36' 6" Grecian IG Pool. Hayward Swim Clear cartridge filter and 1HP Hayward pump
    Will be installed at the end of July!!!
    BayScoutTim's Avatar
    Aug 2013
    North East Florida
    36
    Re: New Vinyl Pool in the Buckeye state!
    Yep! Coming along nicely. Keep the pictures coming. It is great inspiration for Us and a lot of support for You.
    BayScoutTim
    :: 28' round Doughboy AG (18,400 gallons) :: Hayward 1-1/2 hp Power-Flo Matrix pump :: Hayward Pro Series 21" top mount high-rate sand filter 65GPM :: Hayward Vari-Flo XL 7-way valve :: AquaBot Breeze 4WD :: TF-100 XL test kit :: SpeedStir magnetic stirrer ::
    30,421
    After splitting 10 cords of wood, I am surprised you have the strength to get up out of the hospital bed.
    That's not a job for sissies! Very ambitious.
    Jul 2012
    Ohio
    19
    It was a process not an event. I dropped the trees last fall and then piled up the wood and worked on it over the winter. I try to do all of my own work when I can. The pool is the first project I have ever contracted out. I wanted to tackle it myself but decided to have the pros do it. I have to live with the results for a long time, so I want to make sure it's as close to perfect as possible.
    Aug 2010
    Cincinnati, OHIO
    17
    Another Ohioan here!
    Hydraulically mundane 20x40 rectangular polymer (~30K gal.), IntelliFlo VS+SVRS pump, IntelliChlor IC40 SWCG, Pentair CCP520 cartridge filter, LED light, 2xDeck Jets, SR Smith Turbo Twister slide
    Jul 2012
    Ohio
    19
    Unfortunately the Ohio weather got the best of my install yesterday. The PB got the walls up but by the time I got home everything was tarped over and a storm was rolling in. The weather is supposed to clear up later this morning, so hopefully they can get the sump in today and the footers poured. I'll update the pics once there is progress.
    Jul 2012
    Ohio
    19
    I went home for lunch today and the crew was hard at work. They are pouring the concrete footers and equipment pad today. Hopefully vermiculite tomorrow and then liner on Monday!
    Jul 2012
    Ohio
    19
    Saturday was a great day and the crew put in a long one doing the vermiculite bottom. Liner, back fill and water on Monday. It's starting to look like a pool!
    Aug 2013
    North East Florida
    36
    Great progress on Saturday. Man that is exciting! Looks like a great design as well. A good size pool as well. Hope the weather holds out for the liner install Monday. Keep the pics coming!
    BayScoutTim
    Jul 2013
    Columbus, Ohio
    114
    Nice pool. Mine is about the same size. My only regret is I didn't find this site sooner.
    16,500 gallon, 18" x 38" Grecian; IG Vinyl, Hayward DE
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    BB - Is the white circle in the deep-end a drain? I ask because it looks like there is only one. If it is a drain, for the required anti-entrapment feature there are usually either two circular drains separated by say 2-3' and plumbed together or one longer rectangular drain. I am no expert but it was just an observation.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    I need to update mine...we are also building in Ohio. What part of the state are you in? The rain totally put us sooo behind in our build, but what can you do about that?
    36K gal (40 X 20), IG vinyl w/AC, Hayward single speed Super Pump 1hp, Hayward C1200 Star-Clear Plus 120 sq ft cartridge filter, Hayward AquaPlus SWG
    TF-100 Test Kit, Dolphin Supreme robot
    Cleveland, OH
    Jul 2012
    Ohio
    19
    Quote Originally Posted by amytude
    We are close to the PA border (but buckeyes to the bone!). I was raised in Canton and we're about 40 minutes east of there now. The Ohio weather is never very good, but this year has been the worst! I thought we would be swimming by the end of the first week in August, but everything is behind schedule. Our PB is not messing around, we have had pretty good weather this week and there have been a few nights where he works right up till dark. That makes for a long day when you start at 7am. I've got a few more updated pics to post. The electric work will be finished tomorrow so I'll be running the equipment by end of day on Wednesday!
    Jul 2012
    Ohio
    19
    I haven't posted pictures in a few days because I've been busy. I decided that in order to do the electric right it was going to be over my head. I had the job started and decided to go in a different direction to allow for landscape lights, and some other accessories later down the road. So, I have a friend who is an electrician who came out and worked with me to make sure everything was up to code and done properly. I decided to put a sub panel in by my equipment pad for the pump, pool light and lighting. I also put the pump on a timer. We have all of the electrical done and the pump and light work like a champ!!! I'll post some pics of the equipment shortly, but for now here is an update:
    We have water! Since the electric is done and everything is properly grounded we've been swimming in the pool a couple of times!!! Concrete decking is being poured today!
    30,421
    Lookin' good. Very smart to use that rock backfill.
    Jul 2012
    Ohio
    19
    I had one builder tell me they don't backfill their pool walls. but if I wanted to shovel some dirt around before they poor concrete I could. They had some "support" that the concrete decking sat on. Once I heard that the conversation was over.
    Jul 2012
    Ohio
    19
    So the build is on the home stretch. The concrete was poured last week and the family came over this weekend and we had a cook out and pool party. The diving board, ladder, hand rails and basketball hoop were all set in the sockets last night....that's when we encountered our first problem.
    The sockets for the basketball hoop are not square with the coping. The pool builder feels that one of the concrete guys must have hit it with a wheel barrow. I was skeptical at first but after looking at the situation I am leaning towards agreeing. It's only off about a 1/2" but it is enough to be obvious when looking at the legs of the hoop. Let me first say that I have complete confidence that my builder will make it right, even if he has to rip out some concrete. He has a couple of things he is going to try to square everything up before he goes to the drastic measures of pulling out the pad where hoop sits. He wants to make it right and I am sure that he will. He has been tremendous to work with through this whole project. I'll update the thread once it's resolved.
