Results 1 to 9 of 9
Thread: need help with CH
    Aug 2013
    dallas,tx
    79
    need help with CH
    I have a white line all around the water line on the tile. In the past I have been adding a bottle of scale inhibitor as per the pool store. My CH is 190. I see that I need to have a level of at least 250. I always assumed that white line was calcium.
    What gives and how do I get rid of the white line. I also have large "off whiteish" deposits on the natural stone on the spa overflow. I looks large enough that I could take a chisel and hammer to it.
    2009 19k, IG, Quartzscape negative edge w/waterfall, 8' raised spa w/waterfall ,Pentair WF28 2hp, Jandy 1.5hp pump for water fall feature, Polaris 280 cleaner with booster pump,400,000 Jandy LXI heater, Jandy DE 60 filter.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: need help with CH
    Quote Originally Posted by dkbrat
    If the pool had been subject to regular trichlor puck use, those can leave a residue similar to what you're seeing on the tile. Another possibility is residue from tanning lotions. Given your low CH, it probably not calcium. Therefore, it should come off fairly easily. Several members who had a similar tile ring reported good success using a Magic Eraser ( a Mr. Clean product) to wipe the tiles with. Should be available in the cleaning section of most grocery stores.
    This is efflorescence which is often mistaken for a heavy calcium buildup. The good news is that efflorescence is not a structural or dangerous problem but it is certainly unsightly and can be VERY difficult to remove. I would remove it from the finished areas with a bristle brush and a solution of water/muriatic acid. I would start with a 4:1 water/acid ratio but be prepared to strengthen it. You will know it's working when it "sizzles" or foams up. Just be a bit careful around the grout.
    Aug 2013
    dallas,tx
    79
    Magic eraser did nothing. It is also all over the tile on the negative edge spill way
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Can you post some pics?
    Aug 2013
    dallas,tx
    79
    [attachment=1:2eh8ill8]photo62.jpg[/attachment:2eh8ill8][attachment=0:2eh8ill8]photo65.jpg[/attachment:2eh8ill8]
    30,424
    Sure looks like calcium scale. Can you post a Calcium Hardness test result to get started?
    Aug 2013
    dallas,tx
    79
    CH was 200. I just did a drain and refilling due to CYA of 360. I will post new tests results tomorrow. Prior to changing to BBB method, I have used a scale inhibitor once a month.
    Aug 2013
    dallas,tx
    79
    After drain and refill ch dropped to 150. Have raised to 300
    Aug 2013
    dallas,tx
    79
    Almost a year later, thought I would update how I got rid of the white line just in case someone else has this same issue. Leslie pool Descale it spray. Sprayed, left overnight. Next morning was broken down, but a bigger mess. Mixed acid and water, sprayed it on the smeared mess, scrubbed and came right off. Have been on the BBB method just under a year. Keeping the pool completely in balance seems to have kept the white line from coming back. Not much scrubbing required
