Thread: TA climbing
    Kathyonthefarm's Avatar
    Jun 2008
    Chatham, Ohio
    TA climbing
    My TA keeps climbing............rained 2 days ago, a lot, TA was 150 after the rains(140 before),
    TA 160
    PH 7.3 ( down from yesterday of 7.4)
    FC 6 (will be shocking because there is still green )
    CYA 50
    Cal 200
    Inground, vinyl, 34k, sand filter, FULL sun
    Mar 2007
    San Rafael, CA USA
    Re: TA climbing
    Other than test variation error, there's no good explanation I have for that. If there was evaporation and refill with water that had TA (which most water does), then that will lead to a slow rise in TA over time -- that's what happens in my own pool with fill water that has around 80 ppm TA. Normally rain will help aerate the water and will cause the pH to rise with no significant change in TA (a slight drop from dilution, but probably not measurable). Adding acid, of course, lowers both pH and TA.
