Thread: Pool Liner Issues
    Pool Liner Issues
    Hello,
    We recently installed an above ground pool ourselves. The pool is done and the liner in. We begin filling with water and did not have any issues. After a day, we realized that the sand around the pool is wet. As it is an above ground that the center gets deeper & we are in clay, we believed that water must have been in the bowl under the pool and was being forced out by adding water to the liner. It has been in the 90's for 3 days and is not drying at all, leading us to believe that the liner is leaking. My husband got into the pool to investigate and can not find any holes or odd spots. The weird part is that it is wet all around the pool and not just in a single spot. Does Anyone have ANY Suggestions?? We are new to this and out of ideas.
    The Clavy's
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Pool Liner Issues
    Welcome to TFP !
    If you think your liner may be leaking take a look at this pool-school/leak_detection
    Also wanted to ask if you have a good test kit ? TFtestkits.net. You can get one there.
    Jeff
    Our issue is not pluming as we are not that far yet. Only about 2 foot of water in the pool. But is weird that a 27ft round pool would be damp all the way around.
    itodd's Avatar
    Jul 2013
    Gastonia, NC
    50
    I've had leak issues also. I bought a mask and got in the water with drops of food coloring. That helped me locate a couple of leaks. Close examination helped locate others. I found a couple just walking outside if the pool looking down. My holes have looked like small dark spots.
    4600 gallons, Intex Ultra Metal Frame 14' round 4' depth, SWG, cartridge filter pump, 2500 gph, Pool finish date: 7/16/13.
