Results 1 to 8 of 8
Thread: Tahoe Blue Mini Pebble - to double black or not
    Hi Everyone,
    I am having an IGP installed and wonder if I should go double black to get the deeper color as the pool will not be very deep: 3.5' - 5.5' - 4' sport pool.
    Does anyone have a similar depth with just Tahoe Blue or the Tahoe Blue with Double Black?
    Thanks.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Tahoe Blue Mini Pebble - to double black or not
    You might consider how warm it can get. If you live in a very hot, sunny climate like Texas/Arizona, a dark shallow pool can get very warm.
    Essential Links:
    Thank you. I am in the desert, but like my pool in the low 90's. we'll also be installing solar heating.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    If you like low 90s, go for it!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Enjoy it! I bet it will look beautiful. Just curious, is this color created by adding more black pebble or dye to the plaster base?
    Essential Links:
    It's done by doubling the ratio of Black Pebbles in the mix as far as I understand it.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Pprice01
    I kinda figured so. Thanks for the update.
    Essential Links:
    Oct 2016
    California
    9
    Can you post a picture of your Tahoe with added black? I'm thinking of doing the same.
