Results 1 to 14 of 14
Thread: Help with readings please
    Jun 2013
    Northern NJ
    123
    Ok just used the tf-100 to test my water. My FC =0.25 and my CC=2.5 for aTC of 2.75. My CYA has been at least 100. I stopped using trichlor. The pool calculator says I need over 500 oz of bleach is that right? I'm sure my readings Re correct. I thought if CYA was so high that the chlorine would not be that low. I'm new to this please advise
    Thanks
    36,000 gal IG vinyl. Haywood pump and heater Hayward DE filter blue diamond robot. Hayward Aqua Rite SWG AQR-15
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Help with readings please
    What was your FC sample size? 10 ml or 25ml (almost full)
    How many drops did you add to make the pink go away
    I then assume you added the 5 drops (pink again) and then how many more drops to make the pink go clear on the second test? 2.5 sounds like 5 R-0871 drops.
    I ask as 0.25 FC is not a value you can measure with this kit.
    -- Guy --
    Jun 2013
    Northern NJ
    123
    Yes 10 ml. I will re test and let you know.
    Jul 2012
    Herndon, VA
    419
    What size water sample are you using?
    The instructions say to use 10ml of pool water, resulting in FC results in increments of .5.
    The instructions do have a printing error: after it says "Multiply the number of drops you added x 0.5" it incorrectly states: "(i.e. 14 drops x .05 = 7ppm)".
    This error in the instructions has confused others as well.....
    The instruction card should be corrected, or there should be a little note included that clarifies the mistake, IMO.
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    Jun 2013
    Northern NJ
    123
    Guy I used 4 drops and the solution turned clear then 5 drops of 003 and it remained clear. So I guess my FC is 2 as well as tc. True?
    38,485
    Yes. We typically report FC = 2 and CC = 0.
    Since the FC is way too low for your high CYA, you could have something growing in the water.
    Try the CYA test again with a 50/50 mix of pool and tap water to start, add the reagent, then double the reading. Then you will want to replace water to get the CYA into the recommended range. Followed by at least the OCLT to confirm if there is something in the water and quite possibly the need for the SLAM process.
    EDIT: and 500 oz will raise the FC in your pool by about 8.8ppm. ... depends what the Now and Target levels you entered into the calculator as to whether that was the desired result.
    Jun 2013
    Northern NJ
    123
    And my water is crystal clear. I know I have to drain and replace. I am waiting till we close the pool in a few weeks. Meanwhile , do I add the recommended bleach?
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Yes, your reading are
    FC 2.0
    CC 0.0
    for a 10 ML sample with a scoop of powder, 4 drops of R-0871 to turn clear and then 5 drops of R-003 and it stayed clear.
    OK, so yo have 2FC, this is WAY too low for a CYA of 100+.
    OK...on to the next step:
    What does the water look like?
    Where are you located?
    How much swim season do you have left this year?
    Is clean fill water easy and inexpensive?
    -- Guy --
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I missed your comments I am going to let Jason carry on... I am about to get busy here.
    -- Guy --
    Jul 2012
    Herndon, VA
    419
    Jbizzle....
    Couldnt you also add 1/4 pool water, 1/4 cya reagent, and 50% tap water to test when cya is high?.....and then double the results.
    This would save you 1/4 of the cya reagent.
    Mod Edit: Responses to this post were split to HERE after veering off-topic. jblizzle
    Jun 2013
    Northern NJ
    123
    50/50 mix of cya reads 90 so that's 180 yikes!
    38,485
    OK ....... according to the chart: pool-school/chlorine_cya_chart_shock
    if your CYA were 100ppm, you need to maintain the FC above 7ppm at all times to prevent algae from starting. But, you said the CYA may be higher, so you need to do the dilluted CYA test to find out how high the FC should be.
    I would certainly add at least 4 of the 121oz 8.25% bleach bottles immediately to get the FC up some and then verify the CYA.
    You are going to have to try to just limp through the next few weeks on hope before your drain for closing. And learn for next year to not use so much trichlor.
    @GP ... I don't think it works that way. There is a discussion about this somewhere.
    @ Thesil, well with a CYA of 180ppm, the minimum FC is 14ppm according to the calculator ... that is going to be tough. And remember the pH test is invalid when FC > 10ppm
    Jun 2013
    Northern NJ
    123
    Jason yes I added 3 jugs 0f 8.25 that's all I have Have to run to store for more Season is almost over for us in nj Then I will drain and replace about 50%
    38,485
    You really need to replace about 75% of the water. But no sense doing that before the spring. Maybe you will get "lucky" and have the CYA reduce/disappear over the winter.
