Results 1 to 7 of 7
Thread: Chlorine Drop...
    Jul 2013
    Chicago IL
    83
    Chlorine Drop...
    Last night FC level was at 5.5ish ... Pool has been solar covered , checked today 2.5??...Should i just add enough to raise it back to 5.5 or Slam?
    Pool is very clear , yesterday PH was at 7.2 , i raised it to 7.5. that seems ok
    15ft Round, Above Ground , Rheem 106K Heater , Black Diamond 90 Cartridge Filter, Pool Frog(disconnected) ,TF-100, City of Chicagos finest H20
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Chlorine Drop...
    3ppm drop with the cover on means there's something living in it. Time to SLAM. Do you have a full set of recent results to post?
    Jul 2013
    Chicago IL
    83
    Na , no records saved . Just been adding slight chlorine daily to keep around 5.5. Just noticed today after tf-100 test the 3ppm drop.
    38,371
    So, do a full set of tests and report the results.
    Then we will see if anything should be done before starting the SLAM process.
    Jul 2013
    Chicago IL
    83
    Will do thanx
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Is it a clear or opaque solar cover?
    Clear won't block much UV, thus allowing CL breakdown.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I noticed the "pool frog" in your sig. Are you using it? We would recommend against using it...no need to add copper to your pool water.
