Results 1 to 7 of 7
Thread: Pool Piping Replaced - when to start?
    Jun 2010
    Toronto, Canada
    34
    I just replaced the 2 plumbing lines running between my:
    1) pump and filter
    2) filter and heater
    How long should I wait before turning on the pump and heater? I want to make sure the primer and pipe cement are fully bonded.
    20,000 Gallons Inground Vinyl Pool, 1 skimmer, 1 floor drain, 4 return jets, 1 vacuum intake
    Hayward Vari-Flo XL sand filter (SM2506T), Hayward EZ Flow Pump (SP-3107X10), Emerson Pump Motor (EB228), Hayward Comfortzone NG Heater, Hayward Chlorinator (CL220)
    22,544
    Re: Pool Piping Replaced - when to start?
    What does the instructions on the containers say?
    There are so many different brands of cement with so many different cure times it's impossible for us to say how long to wait.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I'm pretty sure the PVC cement cans typically say 24 hours...better honor that, I think. I've blown bubbly glue out of joints before when I was impatient.
    38,271
    Really, I should read more closely. I thought you were good after a couple hours at most. Pretty sure I did not wait a full day after redoing my pad plumbing or adding the SWG.
    Oct 2009
    3,899
    Yeah, that's what mine said...which I only read after I was doing some irrigation plumbing and pressurized it after about a half hour, and blew blue glue out of several of the joints. That was 60 psi and a pool is not, but waiting one day isn't going to hurt anything.
    22,544
    I actually have some that says an hour, but I also have some that says 24 hours. So there's a wide variety in cure times.
    Jun 2010
    Toronto, Canada
    34
    Thanks, guys. The can I used only said "quick drying" and didn't mention curing time. Therefore, I'll wait 24 hours just to be safe.
