Thread: Start Capacitor replacement question
    May 2013
    Bensalem, PA
    13
    Hi,
    From doing some research in the forums, I've come to the conclusion that my Hayward Power-Flo Matrix pump needs a new start capacitor. I turned off the pump yesterday to clean out my skimmer baskets and when I attempted to restart the pump, all I got was a humming sound.
    I checked the inside of the pump to see if something was obstructing the pump and it was clear.
    My question is, would I have to actually dis-connect the pump from the filter and pool in order to replace the capacitor?
    I'm not sure I want to actually disconnect the pump at this moment, because I can't think of a way to stop the pool water from draining out all over the place once I take the pump from the platform.
    If I have to remove the pump to fix it, is there a trick or any other suggestions anyone would have to stop the water from coming out of the pool?
    22,550
    Re: Start Capacitor replacement question
    You do not have to disconnect the pump from the plumbing. You don't even have to remove the motor.
    There is either a metal can that makes a bump on the motor that the capacitor is under or it's inside the back cover. Make sure the power is off!
    38,301
    You should not have to disconnect the pump or motor from the plumbing ... assuming you have access to the cover on the back of the motor.
    Some motors have 2 caps, one in the rear cover and one on the side ... I am not sure which is the start and which is the run cap though
    Smykowski's Avatar
    Sep 2011
    3,065
    I don't think a Power-Flo Matrix pump has a capacitor. There's a centrifugal switch on the back side which might be dirty/loose/bad, but when I took mine apart, I never saw a capacitor.
    Can you turn the shaft by hand? Have you looked at the impeller to see if it's clogged?
