Results 1 to 9 of 9
Thread: Jacuzzi 190 Sand Filter leaking at pump connecter
    Good Day all.
    I have a Jacuzzi MaxiPlus 190 Sand Filter that is leaking a fair amount around where the pump get connected to it. I have triple checked and my connection to the filter is solid, but it looks like it is in the filter connector itself.
    The other connections on the filter (backwash and return) have threaded pieces inserted that convert the connection to allow the flex pipe to be connected (with clamps), however the pump in connection appears to be built right in on the filter. Since this is an older sand filter, I am not sure if it is actually built in or if the previous owner cemented an attachment in place.
    Does anyone how to fix a leak in the connector is it is built in ? or am I able to remove this connector on this model sand filter ?
    Any help is appreciated.
    Mark
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Jacuzzi 190 Sand Filter leaking at pump connecter
    Welcome to tfp, mmcgarri
    Could you post a picture or two of the connection?
    Thanks for the quick response. I will take some pictures tonight and post them.
    The other two connectors on the Fitler (return and Backwash), both have the threading for 2" on the outside and 1 1/2 or 1 1/4 on the inside, but not the pump connection (where the leak is).
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    From what I can tell, I would guess that part used to be a union that broke, so you are right that part is permanently attached. Since that part is not a proper nipple it is not surprising that is leaking. See the diagram on this page for what i think is your valve (there are a number of variations none that appear to have a threaded connection there): http://www.inyopools.com/pool_parts_6_way_dial.aspx
    To help with giving you ideas on how to move forward, take the hose off and snap another picture and measure the inside and outside diameter of the pipe (and check to make sure the inside is not threaded).
    Here is the connector with the hose off. The opening on the valve is 2" and has the barb end for a 1 1/2" hose. When placing my finger in, I could not feel any threads and the grey piece is not in the all that much (maybe 1/4 - 1/2 of an inch")
    Could I not break it off, scrape off and pieces stuck in there and sand down any existing pvc cement. Clean it up and then cement a new connector piece in place ? Or is there too much risk of damaging the filter head ?
    22,553
    What's it gonna hurt to try? If it doesn't work you're no worse off. You have to buy a new valve top anyway.
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Dave's right, what's it hurt to try.
    Besides your original thought, Pasco makes a ram bit. You cut the old pipe off flush with the fitting, then put the ram bit in your drill and auger out the old pipe from inside the fitting. PVC also doesn't like heat. When it gets up to 140F, it softens up. There's an expensive tool I saw used on This Old House or you could try a heat gun. Just soften the piece you want to remove, not the piece you want to reuse.
    Good luck!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    I have the exact same problem and filter was wondering how you made out before I wreck it thought it turned out stripped it now I see is not threaded in ty
